 Post subject: How to check 7200.7 surface area bad or not
PostPosted: May 6th, 2013, 16:54
any idea of how to check seagate 7200.7 surface area firmware are bad or no bad ??
 Post subject: Re: How to check 7200.7 surface area bad or not
PostPosted: May 6th, 2013, 17:34
spildit did u tell me i have som drive 7200.7 is bzy did u tell me plz what is the is it FW prob ANd plz which is prob for bzy??
PostPosted: May 7th, 2013, 12:08
S I R, Spildit
please tell us, how we can read tracks for seagate with sd doctor seagate,
please
PostPosted: May 7th, 2013, 15:06
salim r u from pakistan ??
PostPosted: May 7th, 2013, 17:39
SD and other tools can make life easier, some works some not. SD box for Seagate has just a lot of bugs, what works works fine, you just have to know what work and what not. I can say it because I use them everyday and have tested them personally.
SD Seagate box CAN write and read TRACKS, the feature doesn't work properly for all the families.
You can read and write MODULES (with some exceptions that don't work properly, again...) but MODULES are not TRACKS.
PostPosted: May 9th, 2013, 1:35
Spildit wrote:
Read tracks from it, if they read ok, then probably it's ok. If they don't read ok, try to write to it (compatible SA tracks), If they don't write then it's BAD !
This method is not true, you may destroy the HDD when you "try to write to it". Be careful and think twice before write down to service area.
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
Users browsing this forum: Bing [Bot] and 243 guests
