 Post subject: ST380815AS 7200.10 FW Repair help
PostPosted: May 9th, 2013, 16:03
Hello everyone
We received a drive in for data recovery and are in need of some assistance. A quick background on the drive, the drive was initially tried on DDI which resulted in the drive clicking. Believing this was a head issue we performed a head swap in the clean room. The donor drive with patient heads IDs properly and images without error, so the heads were not the problem. The patient with donor heads initially did go ready and ID properly, but shortly lost readiness and now stays busy. The drive sounds perfectly fine but just stays busy.
Since this appears to be a FW issue, we took a look in HD Doctor. Using HD Doctor I have been able to read in all the FW modules except module 6 (TS) and below I have posted the terminal output as well as the FW diagnosis results. So any help on how to repair the drive would be greatly appreciated and thanks in advance.
Drive:
Seagate ST380815AS
Barracuda 7200.10
Firmware: 3.ADA
HD Doctor Terminal Output:
Reset
4096k x 16 DRAM
NHAWK - 1_Disk    S-42   03-23-07_13:55
HM SFI
(P)SATA Reset
DiskAccess ReadSector EC=43 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
DiskAccess ReadSector EC=47 at ffffffff.00.0080
DiskAccess ReadSector EC=47 at ffffffff.00.0109
Unable To Load Overlay 01|0004
HD Doctor FW Diagnosis Output:
T>
:500000080F000000  AX`9RW0RR26'  "000000000000"13B4B-13CC8
SRAM Ovly = Diag
((Reset
4096k x 16 DRAM
Buzz HM SFI
(P)SATA Reset
DiskAccess ReadSector EC=43 at ffffffff.00.0080
Unable To Load Overlay 01|000A
T>Age=50 Type=0F MxCyl=2158A MxHd=0 MxSct=020 BSz=008M TCode=0100FF00 ThermFlts=0000
Pgm=00 Trk=FFFFF(13BB5:00[1467F]).0(0).080(080) Zn=0 Err=00 ErCt=0000 Hlth=0008 CHlth=0000 Ready LBA=00000505
((VALID Cert Disk Code Detected - Revision # .082
T>y
                  PhysCyl   GrayCyl
1st Sys Cyl      00013B4B  00014615
1st 0 Offset Cyl 00013B55  0001461F
1st App Code Cyl 00013B61  0001462B
2nd App Code Cyl 00013B63  0001462D
2nd 0 Offset Cyl 00013B6F  00014639
3rd App Code Cyl 00013B7B  00014645
4th App Code Cyl 00013B7D  00014647
1st Adaptive Cyl 00013B7F  00014649
1st UsrDfect Cyl 00013B85  0001464F
1st Alt Pool Cyl 00013B91  0001465B
1st CertCode Cyl 00013BAF  00014679
1st IntfCode Cyl 00013BB3  0001467D
1st Intf Sys Cyl 00013BB7  00014681
1st Cert Log Cyl 00013BF1  000146BB
1st Decay    Cyl 00013CAD  00014777
1st SPLASH   Cyl 00013CC7  00014791
Last System  Cyl 00013CC8  00014792
Copy    PhysCyl      StartSec length    Name
0000    0013B55    0000    0001     BootAdaptives
0001    0013B55    00D5    0001     BootAdaptives
0002    0013B55    01AA    0001     BootAdaptives
0003    0013B6F    0000    0001     BootAdaptives
0004    0013B6F    00D5    0001     BootAdaptives
0005    0013B6F    01AA    0001     BootAdaptives
0000    0013B55    0001    0003     RsvTrackDefLst
0001    0013B55    00D6    0003     RsvTrackDefLst
0002    0013B55    01AB    0003     RsvTrackDefLst
0003    0013B6F    0001    0003     RsvTrackDefLst
0004    0013B6F    00D6    0003     RsvTrackDefLst
0005    0013B6F    01AB    0003     RsvTrackDefLst
0000    0013B61    0000    0238     AppCode
0001    0013B63    001E    0238     AppCode
0002    0013B7B    0000    0238     AppCode
0003    0013B7D    001E    0238     AppCode
0000    0013B7F    0000    001C     DriveAdaps
0001    0013B81    0028    001C     DriveAdaps
0002    0013B83    0050    001C     DriveAdaps
0000    0013B7F    001C    0010     MediaZonTbl
0001    0013B81    0044    0010     MediaZonTbl
0002    0013B83    006C    0010     MediaZonTbl
0000    0013B7F    002C    0004     ACFCTbl
0001    0013B81    0054    0004     ACFCTbl
0002    0013B83    007C    0004     ACFCTbl
0000    0013B7F    0030    0004     BackUpACFCTbl
0001    0013B81    0058    0004     BackUpACFCTbl
0002    0013B83    0080    0004     BackUpACFCTbl
0000    0013B7F    0034    0018     AltLst
0001    0013B81    005C    0018     AltLst
0002    0013B83    0084    0018     AltLst
0000    0013B7F    004C    0091     DosTbl
0001    0013B81    0074    0091     DosTbl
0002    0013B83    009C    0091     DosTbl
0000    0013B85    0000    0169     UsrSlipKBALst
0001    0013B87    0000    0169     UsrSlipKBALst
0002    0013B89    0000    0169     UsrSlipKBALst
0000    0013B8B    0000    0169     UsrSlipDftLst
0001    0013B8D    0000    0169     UsrSlipDftLst
0002    0013B8F    0000    0169     UsrSlipDftLst
T>/2
2>x
Head 00
Zone 00:  00018 - 0265F  1485 (05CD) 934.838
Zone 01:  02660 - 0575F  1430 (0596) 900.000
Zone 02:  05760 - 075CE  1393 (0571) 878.225
Zone 03:  075CF - 09501  1351 (0547) 854.377
Zone 04:  09502 - 0B465  1320 (0528) 829.492
Zone 05:  0B466 - 0D7CE  1265 (04F1) 800.460
Zone 06:  0D7CF - 100C4  1210 (04BA) 765.725
Zone 07:  100C5 - 12C37  1144 (0478) 725.806
Zone 08:  12C38 - 14FA0  1100 (044C) 691.935
Zone 09:  14FA1 - 16BC3  1045 (0415) 662.462
Zone 0A:  16BC4 - 18E06   990 (03DE) 627.096
Zone 0B:  18E07 - 1ACD7   935 (03A7) 593.841
Zone 0C:  1ACD8 - 1CF1A   880 (0370) 554.516
Zone 0D:  1CF1B - 1E769   825 (0339) 527.046
Zone 0E:  1E76A - 20266   770 (0302) 493.548
Zone 0F:  20267 - 2158A   722 (02D2) 466.451
Reserve:  13B4B - 13CC8   640 (0280) 524.653
Total KBAs = 095974CE
2>
 Post subject: Re: ST380815AS 7200.10 FW Repair help
PostPosted: May 10th, 2013, 16:08
Have tried a loader yet?
Users browsing this forum: Bing [Bot], Google [Bot] and 292 guests
