 Post subject: HTS545032B9A300
PostPosted: May 11th, 2013, 1:38
Working with the drive, the drive is Full of RED/GREEN blocks. Usually in WD we do SMART reset & this works fine. But this is same after resetting SMART.
Any advice will be appreciated.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: HTS545032B9A300
PostPosted: May 11th, 2013, 5:26
Need data or not ?
PostPosted: May 11th, 2013, 5:27
yes, for data recovery.
__________
THANK YOU
SHAHI
PostPosted: May 11th, 2013, 14:45
If you get delays only / "some" bads it is a typical case where DDI and maybe DE of PC3000 can help.
OR heads are worn out.
OR the drive was kicked HARD.
Or both.
(I wonder if SA can be completely read and how).
PostPosted: May 11th, 2013, 15:20
yes, SA can be accessed normally, all the modules are fine except DUMP in SA-A
no clicking, no abnormal sound, smooth power. no UNC, only GREEN/RED Blocks. that's why very slow..
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 306 guests
