 Post subject: P list damaged
PostPosted: November 13th, 2005, 13:19
Hy can some one help me to correct a BAD Plist from a Athena 2b0h2 Poker?
to recovery data?
Im try with the option to repair AT PDL in the first the bad Plist
no had a Header like TAP_LD1 and had 512 bytes marked as BAD
42 41 44 21
after repaired with Repair Module Option
the Header was changed to
TAP_LD1 but 512 bytes marked as BAD still, with this change was able to detect the hard disk. then i try to access with DE and found the partition table but when i try to access show me cannot create map . So i try another tool to clone to another hard disk, but found like 2000 sectors with error, then after finished i check the clone and found directories and files , but MFT register had some registers damaged, i try to recovery but wheni recovery files the data has shift ,
for example : from a Word document the header and code would be a Header from a Word document, inhis place , have code from a Web page, and so. many files are shifted my question its this a problem from the PLIST how can i solve to recover the real data
PostPosted: November 13th, 2005, 16:32
If U have the legal copy of the utils, I can share some info on the manufacturer's forum and U can also find valuable ideas in the manual too.
regards,
Users browsing this forum: No registered users and 362 guests
