 Post subject: wd 2061-701640 alternate pcb
PostPosted: May 13th, 2013, 11:01
hellow every one any idea of alternative pcb my pcb is 2061-701640 burn pcb ho which pcb is this alternatoive??
 Post subject: Re: wd 2061-701640 alternate pcb
PostPosted: May 13th, 2013, 11:05
Sticker number: 2061-701640-XXX
PCB number: 2060-701640-XXX
Search for 2060-701640-XXX
P.S.
You miss a piece of code where there are the XXX
PCB also can be fixed usually, if you are good with electronics (of course only if the damage isn't serious).
My firmware database:
PostPosted: May 13th, 2013, 11:19
michael card is damage i see that so how can i fix it i think this pcb are change it fix it i cant more pcb for the this no do u tell me alternative pcb for use
PostPosted: May 13th, 2013, 12:25
i have the same pcb but need to confirm last xxx info as micheal stated.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: May 13th, 2013, 12:30
STICKER NO :2061-701640-V02 01PD6
PostPosted: May 13th, 2013, 12:58
it's quite common pcb in ROYL hdd
__________
THANK YOU
SHAHI
PostPosted: May 13th, 2013, 13:01
is tehre any alternative for this pcb ??
PostPosted: May 13th, 2013, 13:17
AFAIK, no alternate!
you can get it locally. if not found, let me know at the end.
__________
THANK YOU
SHAHI
PostPosted: May 13th, 2013, 13:18
do u saleman of pcb ??
PostPosted: May 13th, 2013, 13:20
NO.
__________
THANK YOU
SHAHI
PostPosted: May 13th, 2013, 15:05
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
PostPosted: May 15th, 2013, 7:49
Not all 640 PCBs are the same . . . some have embedded ROMs; others have external ROMs. You cannot substitute one for the other.
http://www.datasaversllc.com
Users browsing this forum: Bing [Bot] and 219 guests
