 Post subject: Seagate Barracuda 7200.12 1Tb Failure. Spins. "Reboot & S...
PostPosted: September 13th, 2015, 18:30
Hello. I have done some research online and haven't found an answer that works for me yet so I though I would make a thread here with hopes of recovering data from this drive.
Product info:
S/N 5VPAG16Q
ST31000524AS
P/N 9Yp154-520
Firmware: JC49
History:
Comes from Dell Inspirion One system that worked fine. A few days ago I had a couple of issues where it wouldn't load chrome, etc. Started working after a couple of reboots and didn't think anything else of it. This morning, my son was playing Minecraft and got BSOD. Upon reboot and on subsequent reboots, got "Reboot and select proper boot device or insert boot media".
Went into BIOS and it is not recognized. SATA 1 shows as none/empty.
Still makes sounds and seems to be spinning. No crazy noises or anything like that and not completely dead.
I have researched and saw the firmware update issue, but that seems to be with the 7200.11. It also seems to late for that now regardless.
PC is working fine with another HDD so the issue is the Seagate HDD.
Apparently auto backup was turned off (I know how dumb this is now) and a lot of children photos, docs would be gone if no recovery, which would suck bad. I don't have several hundred dollars to pay someone to recover the data.
Would it be worth it to purchase a SATA to USB cord/docking station to see if it is recognized as an external HDD? From other threads I have seen, this didn't work but if there is a chance I am willing to take it. Does giving the hard drive time and trying later ever work? I am not an expert but have basic PC knowledge and can switch out parts, follow direct instructions, etc.
Can anyone help me get the data off or point me in the right direction?
 Post subject: Re: Seagate Barracuda 7200.12 1Tb Failure. Spins. "Reboot &
PostPosted: September 15th, 2015, 16:38
can you upload the terminal log ?
PostPosted: September 16th, 2015, 15:54
I am willing to try. How would I do that?
PostPosted: September 16th, 2015, 17:58
assuming there is no physical problem with the drive (heads/media that can cause further damage)
you have to use a TTL adaptor for that
and follow this guide
PostPosted: September 16th, 2015, 17:59
double post
PostPosted: September 16th, 2015, 19:02
So one of these is what I would need?
http://www.ebay.com/itm/USB-2-0-TO-TTL- ... 3cce436b58
PostPosted: September 16th, 2015, 19:30
It wont let me post links, is this the item I would need on E..Y for $8?
USA! 1 PC OF A WHITE USB 2.0 TO TTL UART CP2102 6 PIN SERIAL CONVERTER MODULE
Users browsing this forum: No registered users and 182 guests
