 Post subject: ST3500413AS busy.....
PostPosted: June 4th, 2013, 1:31
I have ST3500413AS......FW JC45......P/N 9YP142-303
Hdd shows busy only and in terminal it display...
Rst 0x10M
RW: Disc Ctlr Initialization Completed.
No HOST FIS-ReadyStatusFlags 2002A1A5
I tried to clear smart & translator regenerator....
Data is important, So any help will be appreciated.....
 Post subject: Re: ST3500413AS busy.....
PostPosted: June 4th, 2013, 4:55
Hmmm "tried to clear smart & translator regenerator...." dont try this ( if you dont know what problem ) 'coz your HDD will gone forever. You can try to load CERT 1st.
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: June 4th, 2013, 8:28
Does the drive spin down on its own after power on?
PostPosted: June 5th, 2013, 19:52
On F3 ??
PostPosted: June 6th, 2013, 1:46
Hdd spin continue without any clicking noise.....
PostPosted: June 6th, 2013, 12:53
Maybe be some fw damage, maybe a weak head. Tested heads?
PostPosted: June 6th, 2013, 15:30
Rst 0x10M
Hi Dear Friend
Read This Error Carefully "No HOST FIS-ReadyStatusFlags 2002A1A5"
Its Common Problem Of This Drive I Have Solve Many Case Of This Type Of Drives.
Its Common Problem In KC43 And KC45 I Have Solve More Then 30 Case.
If U Want To Know The Real Solution Pm Me Or Contact Me On My MSN Messenger @ jignesh.pankhania@hotmail.com I Will Tell You There.
Bcoz If I Tell Here Admin Ban Me Or Block Me In This Forum.
I Dont Know Why Admin Sir Doing This If I Want To Help Someone When I Am 100% Sure My Solution Works And Data Is Not Damaged.
Its Ok I Dont Share Any Of My Success Or Case Studies Here.
I Just Help With Messenger And If Need I Will Spend My Free Time To Come To Your Teamviewer And Solve Your Problem Without Any Fees.
I Am Also Proffesional Data Recovery Expert And I Dont Say I Am 100% Acurate And I Am Genius Or Something Like Other.
I Am Not Complet And No One Is Complet In This Word All DR Expert Damages Many Hard Drive When They Attempt Head Swap And All Critical Data Recovery Job.
But No One Say That In The Real Life And No One Accept It.
Its Ok I Dont Say Much. Contact Me Anyone When He/She Need Help I Will Help Everyone When I Have Solution. I am Not Say I Have 100% Solution But I Have Very Big Experiance Bcoz I Am More Then 8 Years In Data Recovery Business.
And Sorry For My Bad English.
Yours Friend
Jignesh Pankhania (India/Gujarat/Ahmedabad)
PostPosted: June 6th, 2013, 17:22
Which command did you use to regenerate the translator?
Was it "m0,6,3,,,,,22" or "m0,2,2,0,0,0,0,22" ?
Did you clear the G-list as well?
PostPosted: June 7th, 2013, 1:16
Rst 0x10M
Hi Dear Friend
Yours Friend
Hi
Its nice gesture from jignesh.It seems he is genuinely trying to help. Appreciate the efforts.
PostPosted: June 7th, 2013, 14:31
Banned User
Did you try any softwares? Try connecting it as an external hard drive. Do you have jumpers on your hard drive?
PostPosted: June 7th, 2013, 20:08
Banned User
If the data is important for you, I would recommend you taking it to data recovery specialists
PostPosted: June 10th, 2013, 3:59
We have PC 3000 UDMA to work on it......but no access to the hard drive....
PostPosted: June 12th, 2013, 13:09
Brother Fzabakar
First I Say I Realy Like You And Your Work I Like To Be Your Good Friend. Your Always Help To All People Here And Many Forum I Ready Your Many Post On Seagate Forum Your Work Is Great Keep It Up Brother.
Brother I Dont Use Traslator Directly Without Knowing The Error And symptoms And I Give You The Hind Dont Use Any Traslator Command If You Are Not Sure What Is The Problem Bcoz If The Problem Is Not Traslator And You Apply Translator Commands And We Fix That Drive That Time Drive Is Going To Partial Sector Access Problem In Pc3000 Use Says It Broken Traslator.
So If You Want To Know How To Solve This F3 Drives Problem I Need To Show You 3 symptoms And 4 Method So Then You Can Understand Wich Time We Need To Apply Translator Command And Wich Time And Problem We Use Other Solution.
Almost You Apply My Solution Drive Work Like Nothing Happend And In The 2 symptoms I Dont Use Any Of Traslator Commands.
Brother Fzabakar Add Me In Your MSN Messenger And We Will Talk In Details On This Problem If You Like.
My MSN Email Is : jignesh.pankhania@hotmail.com
Yours Friend
PostPosted: September 12th, 2013, 14:47
hi
this error (No HOST FIS-ReadyStatusFlags 2002A1A5) occur due to two reason .
1. due to software corruption .
2. due to head stuck and clicking
solution if software problem
when u get F3T> enter m0,2,2,,,,,22
then clear smart then power reset .
error goes
thanks
waqasali766@hotmail.com
