 Post subject: Hitachi HTS5450B9A300
PostPosted: May 30th, 2013, 6:13
Hi
I git this drive, that had a stiction (the client said that there wasn't no crashes). I have unstucked heads, all seems fine on heads.
But I found 2 light scratches on the outer edge of the top platter.
I tried to see if it works, but it clicks.
Can it be heads or does these scratches affect the SA?
ACELab partner
 Post subject: Re: Hitachi HTS5450B9A300
PostPosted: May 30th, 2013, 8:11
HI
i think its Heads Try to swap Patient Heads to Donor HDA & see if its work then problem with Patient Platter Scratch.
PostPosted: May 30th, 2013, 9:40
Honestly I cannot see clearly the scratches from this picture, anyway inspect first with microscope and check with donor HDA.
Where were the heads "parked" ? (middle, OD, ID...)
PostPosted: May 30th, 2013, 10:17
Hi
They were parked in the middle.
The scratches are very thin.
If you zoom enough the image, you can see it.
ACELab partner
PostPosted: May 30th, 2013, 11:19
Try to swap heads first. Then try to take an image as fast as you can.
Good luck
PostPosted: May 30th, 2013, 14:56
Heads replaced and SQL database recovered.
Thanks guys.
ACELab partner
PostPosted: May 30th, 2013, 15:03
Congratulations. :)
Good job
PostPosted: May 30th, 2013, 16:08
Good job, loves those drives with their "floating" magnets :D
http://www.rescue-it.se
PostPosted: June 7th, 2013, 15:45
Banned User
Always glad to hear that data is recovered, its like a magic word :!: :)
Users browsing this forum: Google [Bot] and 243 guests
