 Post subject: Toshiba mk5076gsx unlock
PostPosted: June 17th, 2013, 10:14
This toshiba mk5076gsx has password locked and hdat says master password has changed
It have a spi eeprom in the board and dumpit I hope the password stores there
but dont found a way to desencript
File comment: eeprom dump
hdd toshiba mk5076gsx.room.zip [184.19 KiB]
Downloaded 699 times
 Post subject: Re: Toshiba mk5076gsx unlock
PostPosted: June 18th, 2013, 12:12
The only I want is unlock there's anoter way
its seems a virus has locked the driver "master password has changed "
I see a virus that uses the serial for master password but this new
Toshiba seems to have a terminal interface like segate but I found nothing
in the bios I see UART and terminal related stuff
any way to unlock ?
Fasterase dosent work and never work for me in other cases
PostPosted: June 18th, 2013, 13:27
Or it may be just firmware damage. Not saying it is, but could be.
PostPosted: June 18th, 2013, 15:52
Reflash is an option?
i don't find another room
PostPosted: June 18th, 2013, 16:32
Don't mess with the ROM. No need to flash anything.
Someone with the proper knowledge and tools needs to rule that possibility out.
The firmware check-up can't be done with conventional tools to my knowledge.
PostPosted: June 19th, 2013, 1:01
Flash with another ROM copy = destroy data.
PostPosted: June 19th, 2013, 3:24
Try ZU:
http://malthus.zapto.org/viewtopic.php?t=166&p=334
PostPosted: June 19th, 2013, 9:42
Youre ok I try whit a broken seagate but pbc works ok maybe
you can flash whit the room of the same model stxxxxx whitout the pc3k i found one in firmware in of the this in this site for pc3k in the room folder is the contents of the eeprom of the disk I flashit using the rayer spi (chepest eeprom flasher) but the only thing that i get is firmware corrupt mensages in the hdat and the terminal the commands say errors everywhere the serial of the disk also change
this is because the firmware also stores in the platers ?
I will try zu seems to be a good and easy solution and post the results
PostPosted: June 19th, 2013, 16:11
Can you post the Identify Device information (model number, serial number, firmware version, capacity, etc)? A tool such as CrystalDiskInfo should be able to provide this info in text format.
PostPosted: June 20th, 2013, 9:09
thank fzabkar !!
ZU ok 100% unlock!!!!!!!!!!!!!
The ZU is the best I can belive how easy its work
ZU /S unlock 100%
Users browsing this forum: No registered users and 210 guests
