 Post subject: 10K/sec recovery rate off WD 1TB 2.5", possible cause?
PostPosted: June 18th, 2013, 5:16
Just performing a data recovery on a WD 1TB 2.5" (WD10JPVT) that came from an enclosure. No noises, no errors (yet!), using GNU ddrescue on Linux to recover [ as per many dozens of drives before this one ], but the thing that struck me as odd is that I'm getting a miserable 10KB/sec, yes, that's incredibly slow and I'm worried the drive will die from read attempts before it gets anywhere.
I've plugged it in to a separate USB3 docking station that I use for most of my recovery processes ( normally see 40~120MB/sec ).
Any ideas what can be the culprit in these situations on the drive causing the tremendous slow down?
The data appears to be legitimate, running photorec on the partial image already pulls out a few valid EXE files that are found on these portable drives by default.
You have a backup...right? | Tech Repairs on YouTube
 Post subject: Re: 10K/sec recovery rate off WD 1TB 2.5", possible cause?
PostPosted: June 18th, 2013, 7:17
Update: some more data...
I noticed that all communications with the drive are quite slow, even hdparm settings such as trying to adjust the look-ahead feature and power-down timeout.
PostPosted: June 18th, 2013, 7:35
The drive is dying fast... Needs a new set of you know what.
PostPosted: June 18th, 2013, 7:41
Might be some head is dirty/weak slowing down the entire process, or Mod32 could need to be fixed, or...
PostPosted: June 18th, 2013, 8:53
I pulled up the SMART data, also the drive runs quite cool, and it doesn't *sound* like it's doing a lot of repeating seeks. All interactions with the drive are exceedingly slow, even when you're not reading from it (ie, just querying the controller), that's the confusing bit. That said, the SMART seek error rate is absurdly high I suppose :(
As you say Northwind, could be a weak head :(
root@ctpc001:~# smartctl --all /dev/sdd
smartctl 5.41 2011-06-09 r3365 [i686-linux-3.2.0-40-generic-pae] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model: WDC WD10JPVT-00A1YT0
Serial Number: WD-WX81C62A4510
LU WWN Device Id: 5 0014ee 207461097
Firmware Version: 01.01A01
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Tue Jun 18 22:52:56 2013 EST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (17700) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 192) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x70b5) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 10
3 Spin_Up_Time 0x0027 130 127 021 Pre-fail Always - 4466
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 235
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 051 051 000 Old_age Always - 3642
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 400
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 145
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 32
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1974
194 Temperature_Celsius 0x0022 116 108 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 3
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
PostPosted: June 18th, 2013, 13:25
Though I have not yet seen mod32 issue on this model, Northwind has a good point, could be a factor as well.
PostPosted: June 18th, 2013, 19:25
Thanks folks. I think time time around I'm just going to have to accept that it's beyond the recovery limits of my software tools ( ddrescue, photorec etc ) and forward the client on to a clean room service provider.
Anyone know of a reputable provider in Australia?
PostPosted: June 19th, 2013, 2:58
Yes,
www.datarecovery.com.au
ask for Eric.
PostPosted: June 19th, 2013, 5:51
Thank you Northwind, a pleasure to have your presence here and providing such assistance.
PostPosted: June 20th, 2013, 4:10
You're most welcome :-)
PostPosted: June 21st, 2013, 0:35
UPDATE: While I'm waiting to hear back from Eric as per Northwind's suggestion, I was going over the logging data I got from the ddrescue process, and there was a bit of a quirk that I noticed;
The initially start at about 10KB/sec, then after two or three reads, then the next 2~4MB of data would transfer at about ~500K/sec, before falling back to the 10~15KB/sec rate. I can repeat this by cycling ddrescue (terminating the process and restarting). It's not drive sector dependent, it is influenced by the drive read-ahead settings. Initially I thought it was just a buffering / timing miscalculation, but the trouble is that the 4MB of data transferred would occur in a time period quicker than that average overall. It could still just be an artifact of the multiple levels of buffering between the read heads and the ddrescue app, though it does make me ponder.
PostPosted: June 25th, 2013, 2:30
While I've been discussing matters with Eric, I had the hard-drive on some testing, and it certainly does come up looking very much like a head-failure.
Just thought I'd show what it looks like in ddrescue;
PostPosted: June 25th, 2013, 18:31
bad head, adaptives, translator etc.
Users browsing this forum: Google [Bot] and 67 guests
