 Post subject: Seagate ST3500320AS - able to detect but unable to image
PostPosted: June 19th, 2013, 10:52
I have a Seagate ST35000320AS - 500GB Drive
Firmware: SD04
The drive gets detected in PC3K, shows the correct size, I can even view the folders and files.
But when I try to image used sectors map, after few thousand sectors in green, the drive gives a continuous mild whirr sound and all the sectors shows black in PC3K. I tried building heads map and it seems that all heads give the same black sectors, so I believe the problem is not due to a single head crash.
I tried DDI, the drive becomes not responding after few thousand sectors of successful imaging
Is it heads or firmware issue?
 Post subject: Re: Seagate ST3500320AS - able to detect but unable to image
PostPosted: June 19th, 2013, 10:57
does it lose ready state? Do status register change at all? Did you check relocation options under HDD ID?
PostPosted: June 19th, 2013, 17:13
I would try head by head...
http://www.rescue-it.se
PostPosted: June 20th, 2013, 4:22
Or backwards..
PostPosted: June 20th, 2013, 8:49
It does not lose ready state, when all sectors goes to black, registers DWF, ERR, ABF is red, DRD, DSC remains green
Sorry I am not sure on checking relocation options under HDD ID, any tips on how do that?
Thanks for your help
PostPosted: June 20th, 2013, 8:52
Now I am trying just Head0 backwards, will update on the progress
PostPosted: June 30th, 2013, 8:46
H2 was the problem. All other heads able to image without issues.
As suggested imaging was done backwards with each head. Except Head 2 all other 3 heads ran successfully.
I believe need to replace the head to get 100% recovery ?
Users browsing this forum: No registered users and 146 guests
