Fujitsu 2,5'' MHZ2 terminal connection
May 6th, 2011, 10:37
if you want to connect to the terminal of the pcb of that disk, you have to solder two pins directly on the pcb in the 2 middle holes of the 4 holes in the top right corner of the pcb (see the attacched photo).
than you may use the terminal connection created to talk with the seagates drive.
I found this solution study the pcb of a case in our laboratory and i share it with all of you as a thank you for the solutions that I found in this forum.
bye!
How I connect the terminal
Re: Fujitsu 2,5'' MHZ2 terminal connection
May 6th, 2011, 11:23
Il problema e' che ci fai poco e nulla...
The trouble is that it is quite useless...
May 8th, 2011, 6:06
Good share :D
May 9th, 2011, 3:56
Beh certo, anche se a volte anche poco può bastare per riportare in linea un hdd per il tempo che serve per il recupero dati.. :)
Well sure, but sometimes a little can be enough to bring on line a hdd for the time it takes for data recovery .. :)
May 9th, 2011, 4:53
Quasi mai da terminale. Di solito devo accedere dalla ata/sata.
Rarely. Usually I have to use ata/sata interface.
May 15th, 2011, 11:43
italianrecovery wrote:if you want to connect to the terminal of the pcb of that disk, you have to solder two pins directly on the pcb in the 2 middle holes of the 4 holes in the top right corner of the pcb
Thank you for sharing.
May 15th, 2011, 12:20
AFAIK, there is no echo with Fujitsu SIO, and the command set is proprietary. And not shared.
So . . . now that you have established a serial port connection, what do you do with it? How does it help you with the recovery process?
May 15th, 2011, 14:31
jono-ats wrote:AFAIK, there is no echo with Fujitsu SIO, and the command set is proprietary. And not shared.
*MAYBE* in just one-two case . To me it is almost totally useless.
June 27th, 2013, 3:36
italianrecovery wrote:if you want to connect to the terminal of the pcb of that disk, you have to solder two pins directly on the pcb in the 2 middle holes of the 4 holes in the top right corner of the pcb (see the attacched photo).
bye!
PC3K asks for terminal connection when it comes to unlocking fujitsu hdds. Maybe not for all the models , I don't know but for mine it was necessary.
It was a password protected hdd. Fujitsu MHY2250BH. There wasn't compatible terminal adapter for this drive that time. Then I tried to use seagate terminal adapter as you said.
SO this method worked very well for me!
Thank You! :D
