June 21st, 2013, 9:51
Hi all gurus;
I have here for this drive:
HITACHI
HTS727550A9E364
500 GB 2,5" SATA 3.0
MLC: DA4217
PN: H2T5001672S 0J18811
APR-12
PCB STICKER: 0J14319 DA4730_ Pzy213 0RWM
I want to read drive FW with PC3K for get a copy off FW.
i can read secs (not using PC3K), Drive works fine, and in if i atach to PC3K it cames ready.
but PC3K do not recognize this model, and i can not start utility.
Any way to get FW in this case?
Thanks to all gurus.
Bye
June 21st, 2013, 10:28
Which pc3k do you have?
UDMA or PCI?
I don't think that the PCI version supports this drive, UDMA surely!
June 24th, 2013, 7:56
Yep. UDMA supports it.
June 24th, 2013, 11:43
dmarques wrote:Yep. UDMA supports it.
opss, i have UDMA version.
i atach pic
- Attachments
- Pc3KUDMA.JPG (4.87 KiB) Viewed 13080 times
June 24th, 2013, 11:50
So you shouldn't have problems with that.
June 24th, 2013, 12:11
dmarques wrote:So you shouldn't have problems with that.
Ill try to update it. maybe any install problem
June 24th, 2013, 12:56
And is the hdd working fine?
June 24th, 2013, 13:00
dmarques wrote:And is the hdd working fine?
Yes,
I explain de situation
I have a patient drive, i suppose bad heads, or bad FW.
I get a donnor drive, i wnat to make fw saving before start testing.
them Heads exchange. but PC3k do not recongnize bad drive, and not recognize donnor drive (this donnor drive works fine)
Thanks dmarkes for your help
June 24th, 2013, 14:23
Have you tryed ARM menu?
June 24th, 2013, 14:42
Hi mr_spokk;
ARM Menu?, what do you want to say?
June 24th, 2013, 15:09
HITACHI-IBM-ARM family below HITACHI-IBM, which is the default family
June 24th, 2013, 15:11
hhddrec wrote:Hi mr_spokk;
I'm not at work right now, but I believe this drive is ARM.
June 24th, 2013, 17:17
Yep, I also think that's ARM (if I remember well).
June 25th, 2013, 5:56
Thanks dmarques and mr_spokk;
dmarques wrote:Yep, I also think that's ARM (if I remember well).
i send you a pic from PC3K
maybe my PC3K is wrong?
- Attachments
June 25th, 2013, 6:21
hhddrec wrote:Thanks dmarques and mr_spokk;
With that menu you don't have UDMA..only Pc3000....then you can forget to work with ARM drives.
Is it a nice Chinese version perhaps
Should look like this:
mr_spokk on June 25th, 2013, 6:25, edited 1 time in total.
June 25th, 2013, 6:22
mr_spokk wrote:hhddrec wrote:Thanks dmarques and mr_spokk;
No!, is an oficial version!
I do not untherstand!
June 25th, 2013, 6:33
Can you post here the version of PC3K.
June 25th, 2013, 6:55
dmarques wrote:Can you post here the version of PC3K.
Here is:
- Attachments
June 25th, 2013, 7:33
Most possibly this is an outdated UDMA version. When did you update it last? If more than a year ago, then you have old version and you need to update it.
June 25th, 2013, 7:58
5.2.6 is that latest as I know...go to your updatebox and upgrade.
