 Post subject: hard disk has no power
PostPosted: July 5th, 2013, 8:38
dear friend & seniors
I have a hard disk
seagate BARRACUDA ATA
Model ST320011A
i have replace a damaged pcb with ok pcb but hard disk has no power
please guide me how i solve this problem
 Post subject: Re: hard disk has no power
PostPosted: July 5th, 2013, 8:51
IF PCB is compatible, either headstack is killed (you have a precise output) or motor is killed, or both.
Time for cleanroom work :(
PostPosted: July 5th, 2013, 9:17
Doesn't work :mrgreen:
PostPosted: July 5th, 2013, 9:32
I mean that
Try to place a piece of paper or card or plastic insulating the head stack contact from the PCB.
If the drive spins that way then pre-amp is shorted, preventing the drive from spinning.
won't work :mrgreen:
PostPosted: July 5th, 2013, 11:05
Dear Spildit
yes drive spin up
what is (pre-amp is shorted)?
PostPosted: July 5th, 2013, 11:13
If you remove contacts from heads you should get an error in terminal and motor SHOULD NOT spin up .
So either the problem is elsewhere or something is missing from the diagnose.
Anyway if something at HS is badly shorted it will prevent EVERYTHING from starting and can kill a new PCB also.
PostPosted: July 5th, 2013, 15:12
The damaged chip is the motor controller, and the damage is on the motor side. Did you measure the resistances between the motor terminals?
You could also verify the voltages at the LX8815-33 regulator and the FDFS2P102A FETKY. See the attachment.
FDFS2P102A, Integrated P-Channel PowerTrench® MOSFET and Schottky Diode, Fairchild, 20V, 3.3A:
http://smartdata.usbid.com/datasheets/u ... 2p102a.pdf
LX8815-33, 3.3V, Linfinity, Dual Channel 1A Low Dropout Regulator:
http://www.datasheetcatalog.org/datashe ... SC1645.pdf
PostPosted: July 5th, 2013, 17:54
Spildit wrote:
But if the drive spins up when you have the head stack contactes insulated ...
AIUI, what he's saying is that this is one of those drives where the MCU needs to be able to see the preamp before it even tries to spin up the drive.
Preamps have a serial interface by which they communicate with the MCU. You can see it in the following block diagrams:
http://malthus.zapto.org/viewtopic.php?f=59&t=229&p=582
Users browsing this forum: Google [Bot] and 227 guests
