 Post subject: HM321HX PCB defective
PostPosted: August 18th, 2014, 11:21
Hello friends ..
i have this drive with PCB issue .
i would appreciate if someone can assist fixing this PCB as no donor available ..
thank you
 Post subject: Re: HM321HX PCB defective
PostPosted: August 18th, 2014, 11:53
What are the symptoms ?
Disk not spinning up?(any power surge problem reported by client ?)
Checked the input voltage (+5v) beyond the usb connector?
any components getting unusually hot?
you can check input voltages across capacitors
If you have an oscilloscope you can check the signals better than multimeter
but some more information required from your side
good luck
PostPosted: August 18th, 2014, 18:29
These threads might help:
viewtopic.php?f=1&t=25581
viewtopic.php?f=1&t=18075
PostPosted: August 25th, 2014, 13:20
thank you friends ,
i will look deeper into this and report back :)
hopefully with good news
Users browsing this forum: No registered users and 50 guests
