 Post subject: 5400.6 ST9500325AS
PostPosted: July 18th, 2013, 6:36
The HDD with "0 LBA" problem. MODEL/SN/FW detects fine.
I can read all modules except module "002B", also I can read all CP (ROM & RAM). So, r/w head should be fine.
I am having the error on "ST9500325AS" 5400.6.
Before proceeding to fix the 0 LBA, I want to be sure about "Partial Sector Accessibility".
SD has a feature to regarding this Issue. Anyone successfully worked with this feature for 5400.6 drives yet?
Following log is generated from the HDD
Rst 0x08M
RW cmd 0002 req = 89 3E 00 00 17 02 00 00 00 00 00 00 08 8C 08 00 87 97 09 00 08 8C 08 00
            opts = 00001121
RW Err = 43110081
RW cmd 0002 req = 89 3E 00 00 01 00 00 00 00 00 00 00 08 8C 08 00 87 97 09 00 08 8C 08 00
            opts = 00001121
RW Err = 43110081
RW cmd 0002 req = 75 5F 02 00 17 02 00 00 00 00 00 00 08 8C 08 00 87 97 09 00 08 8C 08 00
            opts = 00001121
RW Err = C3160084
RW cmd 0002 req = 75 5F 02 00 01 00 00 00 00 00 00 00 08 8C 08 00 87 97 09 00 08 8C 08 00
            opts = 00001121
RW Err = 43110081
ASCII Diag mode
F3 T>
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: 5400.6 ST9500325AS
PostPosted: July 18th, 2013, 7:27
002b is related directly to translator so you need to regen translator, but before you do anything you should check output from "V40" at "T>"
PostPosted: July 18th, 2013, 7:28
Rst 0x08M
            opts = 00001121
RW Err = 43110081
            opts = 00001121
RW Err = 43110081
            opts = 00001121
RW Err = C3160084
            opts = 00001121
RW Err = 43110081
ASCII Diag mode
F3 T>
Dear Friend shahij
Contact Me On Skypee I Have Solution If Drive Have No Physical Clicking Or Very Low Trrrrrrr Sound.
My ID : jignesh.pankhania@hotmail.com
Your Friend
Jignesh Pankhania
PostPosted: July 18th, 2013, 8:04
@hddguy
F3 T>V40
Nonresident GList          27 entries returned
Total entries available: 27
    PBA    Len  Flags  Phy Cyl Hd  PhySctr    SFI
25EB852    3      0     142E   2    678    8C3D9
25EBEE4    3      0     142D   2    588    8C459
25EC575    3      0     142C   2    497    8C2ED
36E5FC9F    3      0    2225D   3    2ED    495A0
36E600A6    3      0    2225E   3    25A    4961E
36E604AC    3      0    2225F   3    1C6    494B1
373DF0CA    3      0    2274E   3     EC    3849E
373DF4D1    3      0    2274D   3     59    3851C
373DFD71    3      0    2274C   3    45F    383AF
376DD804    3      0    22A09   3     94    3D493
376DDC0B    3      0    22A08   3      1    3D503
376DE4AB    3      0    22A07   3    407    3D397
3782675E    3      0    22B33   3     E2    2BDFD
37826B65    3      0    22B32   3     4F    2BE6D
37827405    3      0    22B31   3    455    2BD01
37831B06    3      0    22B4D   3    114    264EF
37831F0D    3      0    22B4E   3     81    2656D
378327AD    3      0    22B4F   3    487    263F2
378365C1    3      0    22B5D   3    22F    495A0
378369C8    3      0    22B5E   3    19C    4961E
37836DCE    3      0    22B5F   3    108    494B1
37839716    3      0    22B68   3     E6    57526
37839B1D    3      0    22B69   3     53    575A5
3783A3BD    3      0    22B6A   3    459    57438
378AAEEC    3      0    22BDA   3    108    21DF3
378AB2F3    3      0    22BDB   3     75    21E63
379037EC    3      0    22BF4   3    2AA    27C17
37903BF3    3      0    22BF3   3    217    27C87
37903FF9    3      0    22BF2   3    183    27B1B
3790A62C    3      0    22BDC   3    27A    21CF7
379844B3    3      0    22C9C   3    3DB    758AA
379848BA    3      0    22C9D   3    348    7591A
37984CC0    3      0    22C9E   3    2B4    757AE
379F1E3F    3      0    22D01   3    185    2885B
379F2246    3      0    22D02   3     F2    288D9
379F264C    3      0    22D03   3     5E    2876C
37A57EE1    3      0    22D4B   3    283     E55E
37A582E8    3      0    22D4C   3    1F0     E5CE
37A586EE    3      0    22D4D   3    15C     E462
F3 T>
@jignesh
adding you ...
__________
THANK YOU
SHAHI
Users browsing this forum: Google [Bot] and 165 guests
