 Post subject: which is my nv-ram?
PostPosted: July 25th, 2013, 14:32
I switched my pcb on my harddrive with a new pcb and i need to swap my nv-ram for my HD to run properly. But im a little puzzled on which one is it, or do i need to switch both of the chips?
File comment: which is my nv-ram?
 Post subject: Re: which is my nv-ram?
PostPosted: July 25th, 2013, 14:47
NVRAM=S93C86
PostPosted: July 25th, 2013, 14:52
plz swap this u drive is work now perfectly
PostPosted: July 25th, 2013, 15:54
so im confused should i switch the two 8 pronged chips or just one of them? Hardrecover circled the opposite one of what moltke said was the nv-ram? thank you for your posts.
PostPosted: July 25th, 2013, 16:32
Moltke is correct. That said, "NVRAM" is an unfortunate misnomer that could easily be applied to either chip as both are "non-volatile". It can't hurt to do what Spildit suggests, although I'd transfer the S93C86 first.
BTW, what is the problem with the patient PCB?
PostPosted: July 25th, 2013, 17:28
Spildit wrote:
as long as you are confident that you can solder them well without damaging the chips and the components around them.
Based on the questions in the OP's previous thread on this topic here:
viewtopic.php?f=1&t=26497
... I personally have doubts that it's realistic for the OP to attempt this themselves. :(
PostPosted: July 25th, 2013, 17:33
That's why I make people aware of PCB vendors who will do such jobs for free. TV repair shops should be able to do it, too.
Perhaps we should be making people aware of in-circuit programming using SOIC/SOP chip clips and a cheap SPI/microwire programmer. It's an additional cost (~US$20 - $30), but it's probably worth it.
PostPosted: July 26th, 2013, 4:13
Swap both of them, but make sure you are not rotating the chips.
Think before you act => Most of the time there is only one chance for recovering lost data !
Users browsing this forum: Majestic-12 [Bot] and 55 guests
