 Post subject: Seagate Barracuda 7200.11 clicking noise
PostPosted: July 24th, 2013, 14:40
Hey guys, I have a Seagate Barracuda 7200.11 HDD from a Maxtor 1TB Basics External HDD. The drive is no longer recognised by Windows when plugged in via USB. The drive is still within the Maxtor enclosure and runs off the power supply and USB lead provided with this. When the drive is plugged in it spins up, clicks, then spins down and constantly repeats. Below is a video I have found on Youtube demonstrating the exact issue I am having.
http://www.youtube.com/watch?v=3zUmdd4PewA
Does anyone have any idea what this could be? Sounds like the bearings could be stuck? Let me know if you need anymore info.
 Post subject: Re: Seagate Barracuda 7200.11 clicking noise
PostPosted: July 24th, 2013, 16:03
Could be a number of things, but stuck bearing is not one of them.
Could well be a firmware issue, but its not a DIY thing I'm afraid.
PostPosted: July 25th, 2013, 4:35
... and get a terminal output.
PostPosted: July 25th, 2013, 9:00
Thanks for you replies guys.
@Spildit I don't have access to a PC with a SATA connection to try, so I was thinking of getting something like this
http://www.ebuyer.com/341689-startech-usb-2-0-to-sata-ide-adapter-usb2sataide, to see if it works.
@northwind How do you get a terminal output?
PostPosted: July 26th, 2013, 8:35
Thanks for the links Spildit, I'm going to see if I can get hold of a PC to test the drive with. If I was to get a TTL adapator, what would that tell me?
PostPosted: July 26th, 2013, 9:07
The drive will post its status report to the terminal.
Users browsing this forum: Majestic-12 [Bot] and 55 guests
