 Post subject: st31500341as with bad head ?
PostPosted: July 28th, 2013, 11:08
hello all ;
i have this st31500341as with head map 01234567
head 0 is semi-dead , and when ever trying to image some sectors from it , the drive hangs on BSY till a hardware reset command is sent ..
i imaged the other 7 heads successfully , but a critical DB is fragmented , and some portions of it located into the h0 area .
any ideas other than replacing heads ?
just to relieve this head to work a little more
thanks
 Post subject: Re: st31500341as with bad head ?
PostPosted: August 12th, 2013, 13:27
What kind of equipment do you have? if don't have none, then data recovery company is your only solution.
PostPosted: August 13th, 2013, 9:41
Have you messed around with timings?
Users browsing this forum: jimmydata and 57 guests
