 Post subject: toshiba MK6025GAS locked disk
PostPosted: April 10th, 2013, 10:53
Hi. I got toshiba MK6025GAS 2.5 60gb HDD, is from defected HP nx6125 laptop, I get this disk and put in Dell Latitude D505 and then I got notice to unlock disk. I must say dell laptop has no set any bios or HDD password.
So I possible to somehow deisabled that password ?
I heard if replace firmware on HDD it will be erased password, but I got poor knowlage on this area.
Is any chance to put that HDD back in business ?
Thank you.
 Post subject: Re: toshiba MK6025GAS locked disk
PostPosted: April 10th, 2013, 11:00
use forum search function - lots of info available
PostPosted: April 10th, 2013, 11:03
Hi. Is possible to give me a point-hint what i must search ? I search toshiba MK6025GAS but nothing usable can find ?
Thank you.
PostPosted: April 10th, 2013, 11:54
"Toshiba unlock"
PostPosted: April 11th, 2013, 7:25
Hi. Thank's for tip. but I can find any usable solution. Is any how-to, I mean what kind devices I need, is laptop or desktop machine OK or I need expert hardware to do this ?
I search some bootable CD etc. with some kind unlock software, I try MHDD and Magic boot disk (both ISO version) and both not detected disk.
Thank you.
PostPosted: April 11th, 2013, 7:54
Some people have been successful using ZU software. Have to read around a lot and experiment.
Another thing is the "locking" state could have occurred for a number of reasons, such as:
1. the drive was purposely locked
2. the drive was never locked but a certain way of failing may cause it to show as "locked" now
etc.
All of these details are important in understanding first the problem/issue, and then and only then determining what the proper solution applies.
Sorry, there aren't any precised step by step manuals or anything like that with conventional, public available, hardware and software. There are advanced data recovery solutions that professionals specialize in and yes they are likely to easily resolve the problem for you, but it costs.
If want professional help, search for a specialized data recovery company using phone and google, get an idea of who can best serve your needs and go for it if deciding to do so.
Best wishes
PostPosted: April 11th, 2013, 8:22
Hi. thx for this post.
I must say, I dont care about data on HDD, I just wont use it in another working laptop.
Is any FREE solution to try (without special devices) unlock this disk, and if success OK. if not goes to trash.
Or is chance if I find mechanic damaged (no spin or click defect) same model and change PCB board, if then chance to this problem disappears ?
Thank you again.
PostPosted: April 11th, 2013, 12:20
Uff final I found this zu.betta.050911 and put on USB with free dos, type cd zu, zu /P but I got feeling to can find disk or something is no OK. it just show Elapsed 00:00:01 and so on work this now about 1h
Im doing something wrong ?
PostPosted: April 16th, 2013, 6:54
What the full service-tag number?
Angel Data Recovery
PostPosted: August 4th, 2013, 16:13
UFF little late, but tomorow I will check what is full tag nm.
thx for now
PostPosted: August 5th, 2013, 2:58
there has been a more recent version
http://malthus.zapto.org/viewtopic.php? ... 6&start=20
PostPosted: August 5th, 2013, 4:03
Ou crap, I can not believe this, this HDD today not response to any thing :)
It's garbage time 100%
Users browsing this forum: Google [Bot] and 87 guests
