 Post subject: Model : ST3250318AS FRM : CC38 Terminal is locked
PostPosted: August 8th, 2013, 5:44
Model : ST3250318AS
FRM : CC38
Terminal is locked
PCB no : 100532367 rev.B
On Power on :
1. Motor Spins
2. ROM is OK
Suggest me 2 points to be shot.
Terminal output :
LED:000000CD FAddr:002582FF
Rst 0x08M
No HOST FIS-ReadyStatusFlags 2002B001
ASCII Diag mode
F3 T>
HighPowerMode
New Skews Pharaoh 0F with VTPI,RAP16,Common Code 3
Product FamilyId: 3F, MemberId: 05
HDA SN: 6VMB1H19, RPM: 7201, Wedges: 120, Heads: 2, Lbas: 2542EAB0, PreampType: 00 00
PCBA SN: 0000K0265QPE, Controller: YETIST_3_*/4_0(649B)(3-12-3-3), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes: 800000
Package Version: PH0G2D.CCD3.AA8400., Package P/N: 100593077, Package Builder ID: AT,
Package Build Date: 09/18/2009, Package Build Time: 14:25:51, Package CFW Version: PH0G.CCD3.00205150.AT00,
Package SFW1 Version: D24C, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 09181425, CustomerRel: CC38, Changelist: 00205150, ProdType: PH0G.CCD3, Date: 09/18/2009, Time: 142551, UserId: 00236537
Servo FW Rev: D24C
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 enabled
 Post subject: Re: Model : ST3250318AS FRM : CC38 Terminal is locked
PostPosted: August 8th, 2013, 8:36
Can c with the log drive is entering into terminal mode ???
PostPosted: August 8th, 2013, 8:39
Search "Read Channel" in the forum.
PostPosted: August 9th, 2013, 18:56
If it helps ...
Tip: How to identify the Read Channel test points:
http://malthus.zapto.org/viewtopic.php?f=24&t=123
PostPosted: August 10th, 2013, 5:18
Take clue from LABTECH
Its already giving u the terminal access
PostPosted: June 6th, 2016, 15:54
What is the solution?
We made a special addition to ROM which is able to catch the control and unlock techno mode at moment of running microcode from surface.
Unlocking is performed in two stages with a simple press of button
Stage 1. Preparation of the drive: ROM patch
2016-04-22_15-15-01 (2) (2)
Stage 2. Unlocking the drive: sending a special session key
2016-04-22_15-54-31 (3) (2)
First button (“Tech mode unlocking preparation, Grenada”) save the ROM via boot code , modify it and write modified image back to HDD. Second button (“Unclock Tech, drive prepared by utility”) send a special command to unlock techno mode. After that terminal commands become working:
2016-04-29_18-47-27 (2)
Solve more previously unrecoverable cases and growth your data recovery business with PC-3000. If you have any questions regarding this feature feel free to contact techical support.
Raminfotech Data Recovery
Chennai's No.1 Data Recovery Center
http://www.raminfotechdatarecovery.com
skp:raminfotech.vijayan
Users browsing this forum: No registered users and 46 guests
