 Post subject: Samsung 2tb drives
PostPosted: August 11th, 2013, 8:40
Hi guys, new to the forum. hope all is well.
I am hoping you have an answer for me that will help.
I have 2 2tb Samsung drives, 1 of them has the PCB that has a burned out motor controller chip (i think) and i need to get the data from it if i can - the 2nd drive is identical apart from one of the components says 4R7E instead of 4R7, i am not sure if it makes a difference because i don't know what it is.
if i try and swap over the boards all i get is a kind of beeping sound as if the heads are trying to spin up but cant.
Thanks in advance
Nathan
 Post subject: Re: Samsung 2tb drives
PostPosted: August 11th, 2013, 9:48
Just for viewing pleasure i am attaching the images of the pcbs.
PostPosted: August 11th, 2013, 15:23
Those components are identical. From what you describe i would say stiction. Probably not DIY.
Murphy was an optimist
PostPosted: August 11th, 2013, 16:16
Are you prepared to pay for professional services? If not, and if the only alternative is to throw the drive away, then try some "percussive maintenance".
BTW, I don't whether your model has unique information on the PCB. If it does, then you will need to transfer the 8-pin serial flash memory chip (below the SDRAM), or its contents, from patient to donor.
PostPosted: August 11th, 2013, 16:39
Hi, The heads don't spin, the patters do. I know what you mean though, and swapping the boards without ID the problem could leave you with 2 blown up boards and no data.
I would suggest contacting a pro. If the Dobre's theory is correct, it is not DIY and anything more you do can be the kiss of death for your data.
I know people must think that we suggest a pro because some pros frequent this forum and we want to drum up business. Well, I am not a pro, but I have seen that yes there are DIY fixes but the percentage of DIY to Pro fixes is small.
Maybe read Jon's draft paper here for what I mean.
http://forum.hddguru.com/viewtopic.php?f=1&t=26584
Cheers
PostPosted: August 12th, 2013, 2:35
thanks for the info guys, i think i'll send it off just got to get quotes now.
