 Post subject: Seagate Barracuda 3TB Spins at start, then beeps
PostPosted: August 13th, 2013, 21:45
Model ST3000DM001
Recently heard a repetitive beeping noise during Time Machine backup. I stopped Time Machine. Since then the drive cannot be recognized in Finder or Disk Utility. When I plug in the drive it sounds like it wants to spin but then does a series of 11 beeps then stops. Removed the HD from the case and used a SATA Drive adapter to go directly to computer - same issue.
Any advice?
 Post subject: Re: Seagate Barracuda 3TB Spins at start, then beeps
PostPosted: August 14th, 2013, 1:00
Most likely the heads are stuck in ramp or on platters.
Advice? If you care about the data, send it to a pro. Nothing much you could or should do yourself.
http://www.datasaversllc.com
PostPosted: August 14th, 2013, 3:56
Agree with Jon. If your data is valuable, your best option is go to a DR pro and ask him for a free diagnosis.
PostPosted: August 14th, 2013, 4:29
with a nod to fzabkar
maybe read up here :
http://forums.seagate.com/t5/Desktop-HD ... td-p/86602
Голод не тётка!
Users browsing this forum: jimmydata and 57 guests
