 Post subject: Failed Seagate ST9500420AS
PostPosted: August 19th, 2013, 16:00
I have a Seagate ST9500420AS which has suffered damage from a dropped laptop. At first it was recognizable in windows and I could read the files on it, but now I can't even get to the files on linux. I managed to get some SMART data before it failed completely, and it looked like it had some bad sectors. Any ideas what the problem might be? Is it hardware?
This is what I get when linux boots up.
root@Forty-Two:~# dmesg
[   26.757758] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757760] sd 3:0:0:0: [sdd]
[   26.757761] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757763] sd 3:0:0:0: [sdd] CDB:
[   26.757767] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757769] sd 3:0:0:0: [sdd]
[   26.757770] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757772] sd 3:0:0:0: [sdd] CDB:
[   26.757763] Read(10): 28 00 00 00 00 00 00 00 08
[   26.757773] Read(10): 28 00 38 91 08 18 00 00 08 00
[   26.757790]  00
[   26.757792] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757794] sd 3:0:0:0: [sdd]
[   26.757794] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757796] sd 3:0:0:0: [sdd] CDB:
[   26.757796] Read(10): 28 00 38 91 08 00 00 00 08 00
[   26.757813] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757815] sd 3:0:0:0: [sdd]
[   26.757816] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757817] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757818] sd 3:0:0:0: [sdd] CDB:
[   26.757823] sd 3:0:0:0: [sdd]
[   26.757824] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757825] sd 3:0:0:0: [sdd] CDB:
[   26.757819] Read(10): 28 00
[   26.757827] Read(10): 28 00 38 91 08 00 00 00 08 00
[   26.757838]  00 00 00 00 00 00 08 00
[   26.757846] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757848] sd 3:0:0:0: [sdd]
[   26.757849] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757850] sd 3:0:0:0: [sdd] CDB:
[   26.757850] Read(10): 28 00 38 91 08 00 00 00 08 00
[   26.757855] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757857] sd 3:0:0:0: [sdd]
[   26.757858] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757860] sd 3:0:0:0: [sdd] CDB:
[   26.757865] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757867] sd 3:0:0:0: [sdd]
[   26.757869] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757871] sd 3:0:0:0: [sdd] CDB:
[   26.757861] Read(10): 28 00 00 00 00 00 00 00 08
[   26.757872] Read(10): 28 00 38 91 08 38 00 00 08 00
[   26.757884]  00
[   26.757893] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757895] sd 3:0:0:0: [sdd]
[   26.757895] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757897] sd 3:0:0:0: [sdd] CDB:
[   26.757897] Read(10): 28 00 38 91 08 00 00 00 08 00
[   26.757902] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757904] sd 3:0:0:0: [sdd]
[   26.757905] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757907] sd 3:0:0:0: [sdd] CDB:
[   26.757910] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757912] sd 3:0:0:0: [sdd]
[   26.757914] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757915] sd 3:0:0:0: [sdd] CDB:
[   26.757907] Read(10): 28 00 00 00
[   26.757917] Read(10): 28 00 38 91 08 00 00 00 08 00
[   26.757930]  00 00 00 00 08 00
[   26.757951] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757953] sd 3:0:0:0: [sdd]
[   26.757954] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757956] sd 3:0:0:0: [sdd] CDB:
[   26.757957] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.757974] sd 3:0:0:0: [sdd] Unhandled error code
[   26.757976] sd 3:0:0:0: [sdd]
[   26.757977] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.757978] sd 3:0:0:0: [sdd] CDB:
[   26.757979] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758004] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758006] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758007] sd 3:0:0:0: [sdd]
[   26.758009] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758010] sd 3:0:0:0: [sdd] CDB:
[   26.758014] sd 3:0:0:0: [sdd]
[   26.758015] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758017] sd 3:0:0:0: [sdd] CDB:
[   26.758011] Read(10):
[   26.758018] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758031]  28 00 00 00 00 18 00 00 08 00
[   26.758043] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758045] sd 3:0:0:0: [sdd]
[   26.758046] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758047] sd 3:0:0:0: [sdd] CDB:
[   26.758048] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758066] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758067] sd 3:0:0:0: [sdd]
[   26.758068] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758069] sd 3:0:0:0: [sdd] CDB:
[   26.758069] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758087] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758089] sd 3:0:0:0: [sdd]
[   26.758090] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758092] sd 3:0:0:0: [sdd] CDB:
[   26.758093] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758113] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758114] sd 3:0:0:0: [sdd]
[   26.758115] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758116] sd 3:0:0:0: [sdd] CDB:
[   26.758117] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758131] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758132] sd 3:0:0:0: [sdd]
[   26.758133] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758134] sd 3:0:0:0: [sdd] CDB:
[   26.758135] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758146] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758147] sd 3:0:0:0: [sdd]
[   26.758148] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758149] sd 3:0:0:0: [sdd] CDB:
[   26.758150] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758172] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758174] sd 3:0:0:0: [sdd]
[   26.758174] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758175] sd 3:0:0:0: [sdd] CDB:
[   26.758176] Read(10): 28 00 00 00 00 18 00 00 08 00
[   26.758188] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758190] sd 3:0:0:0: [sdd]
[   26.758191] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758192] sd 3:0:0:0: [sdd] CDB:
[   26.758192] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758204] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758205] sd 3:0:0:0: [sdd]
[   26.758206] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758207] sd 3:0:0:0: [sdd] CDB:
[   26.758207] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758223] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758225] sd 3:0:0:0: [sdd]
[   26.758226] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758227] sd 3:0:0:0: [sdd] CDB:
[   26.758228] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758244] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758245] sd 3:0:0:0: [sdd]
[   26.758246] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758247] sd 3:0:0:0: [sdd] CDB:
[   26.758248] Read(10): 28 00 00 00 00 38 00 00 08 00
[   26.758259] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758261] sd 3:0:0:0: [sdd]
[   26.758261] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758262] sd 3:0:0:0: [sdd] CDB:
[   26.758263] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758274] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758275] sd 3:0:0:0: [sdd]
[   26.758276] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758277] sd 3:0:0:0: [sdd] CDB:
[   26.758278] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758401] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758404] sd 3:0:0:0: [sdd]
[   26.758405] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758406] sd 3:0:0:0: [sdd] CDB:
[   26.758407] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758415] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758416] sd 3:0:0:0: [sdd]
[   26.758417] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758418] sd 3:0:0:0: [sdd] CDB:
[   26.758419] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.758431] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758433] sd 3:0:0:0: [sdd]
[   26.758434] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758435] sd 3:0:0:0: [sdd] CDB:
[   26.758436] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758443] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758446] sd 3:0:0:0: [sdd]
[   26.758447] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758448] sd 3:0:0:0: [sdd] CDB:
[   26.758453] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758449] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758456] sd 3:0:0:0: [sdd]
[   26.758457] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758459] sd 3:0:0:0: [sdd] CDB:
[   26.758460] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758470] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758473] sd 3:0:0:0: [sdd]
[   26.758474] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758476] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758477] sd 3:0:0:0: [sdd] CDB:
[   26.758481] sd 3:0:0:0: [sdd]
[   26.758482] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758484] sd 3:0:0:0: [sdd] CDB:
[   26.758485] Read(10): 28 00
[   26.758489]  00 00 00 00 00 00 08 00
[   26.758498]  00 00 08 00 00 00 08 00
[   26.758513] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758515] sd 3:0:0:0: [sdd]
[   26.758517] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758518] sd 3:0:0:0: [sdd] CDB:
[   26.758520] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758522] sd 3:0:0:0: [sdd]
[   26.758523] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758524] sd 3:0:0:0: [sdd] CDB:
[   26.758525] Read(10)
[   26.758525] Read(10): 28
[   26.758528] : 28 00 00 00 00 38 00 00 08 00
[   26.758542]  00 00 00 08 00 00 00 08 00
[   26.758556] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758560] sd 3:0:0:0: [sdd]
[   26.758561] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758563] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758564] sd 3:0:0:0: [sdd]
[   26.758566] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758567] sd 3:0:0:0: [sdd] CDB:
[   26.758571] sd 3:0:0:0: [sdd] CDB:
[   26.758568] Read(10): 28 00
[   26.758573] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758586]  00 00 08 00 00 00 08 00
[   26.758600] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758602] sd 3:0:0:0: [sdd]
[   26.758603] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758605] sd 3:0:0:0: [sdd] CDB:
[   26.758607] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758608] sd 3:0:0:0: [sdd]
[   26.758610] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758612] sd 3:0:0:0: [sdd] CDB:
[   26.758613] Read(10):
[   26.758615] Read(10): 28 00 00 00 00 00 00 00 08 00
[   26.758627]  28 00 00 00 10 00 00 00 08 00
[   26.758644] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758645] sd 3:0:0:0: [sdd]
[   26.758647] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758649] sd 3:0:0:0: [sdd] CDB:
[   26.758650] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758673] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758674] sd 3:0:0:0: [sdd]
[   26.758676] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758677] sd 3:0:0:0: [sdd] CDB:
[   26.758678] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758702] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758703] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758705] sd 3:0:0:0: [sdd]
[   26.758707] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758708] sd 3:0:0:0: [sdd] CDB:
[   26.758713] sd 3:0:0:0: [sdd]
[   26.758715] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758716] sd 3:0:0:0: [sdd] CDB:
[   26.758710] Read(10): 28
[   26.758718] Read(10): 28 00 00 03 28 00 00 00 08 00 00 00 08 00
[   26.758730]  00 00 00 08 00
[   26.758737] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758739] sd 3:0:0:0: [sdd]
[   26.758740] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758741] sd 3:0:0:0: [sdd] CDB:
[   26.758741] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758755] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758756] sd 3:0:0:0: [sdd]
[   26.758757] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758758] sd 3:0:0:0: [sdd] CDB:
[   26.758759] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758771] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758772] sd 3:0:0:0: [sdd]
[   26.758773] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758774] sd 3:0:0:0: [sdd] CDB:
[   26.758775] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758780] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758782] sd 3:0:0:0: [sdd]
[   26.758784] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758785] sd 3:0:0:0: [sdd] CDB:
[   26.758789] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758791] sd 3:0:0:0: [sdd]
[   26.758793] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758794] sd 3:0:0:0: [sdd] CDB:
[   26.758786] Read(10): 28
[   26.758796] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758814]  00<6>[   26.758816] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758818] sd 3:0:0:0: [sdd]
[   26.758819] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758820] sd 3:0:0:0: [sdd] CDB:
[   26.758815]  00 03
[   26.758822] Read(10): 28 28 00
[   26.758829]  00 00 00 08
[   26.758834]  00 00 08 00
[   26.758839]  00 00 00 08 00
[   26.758858] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758860] sd 3:0:0:0: [sdd]
[   26.758861] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758862] sd 3:0:0:0: [sdd] CDB:
[   26.758863] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758875] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758878] sd 3:0:0:0: [sdd]
[   26.758879] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758881] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758882] sd 3:0:0:0: [sdd]
[   26.758884] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758886] sd 3:0:0:0: [sdd] CDB:
[   26.758890] sd 3:0:0:0: [sdd] CDB:
[   26.758887] Read(10): 28 00 00 00 08 00
[   26.758894] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.758908]  00 00 08 00
[   26.758921] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758922] sd 3:0:0:0: [sdd]
[   26.758923] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758924] sd 3:0:0:0: [sdd] CDB:
[   26.758925] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.758935] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758937] sd 3:0:0:0: [sdd]
[   26.758938] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758940] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758941] sd 3:0:0:0: [sdd] CDB:
[   26.758946] sd 3:0:0:0: [sdd]
[   26.758947] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758949] sd 3:0:0:0: [sdd] CDB:
[   26.758950] Read(10): 28 00
[   26.758956]  00 03 28 00 00 00 08 00
[   26.758978]  00 00 08 00 00 00 08 00
[   26.758988] sd 3:0:0:0: [sdd] Unhandled error code
[   26.758990] sd 3:0:0:0: [sdd]
[   26.758992] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.758994] sd 3:0:0:0: [sdd] CDB:
[   26.758995] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759004] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759006] sd 3:0:0:0: [sdd]
[   26.759007] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759009] sd 3:0:0:0: [sdd] CDB:
[   26.759010] Read(10): 28 00 00 00 08 00 00 00 08 00
[   26.759031] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759033] sd 3:0:0:0: [sdd]
[   26.759035] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759037] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759038] sd 3:0:0:0: [sdd]
[   26.759040] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759041] sd 3:0:0:0: [sdd] CDB:
[   26.759045] sd 3:0:0:0: [sdd] CDB:
[   26.759042] Read(10): 28 00 00 00 08
[   26.759049] Read(10): 28 00 00 03 30 00 00 00 08 00
[   26.759063]  00 00 00 08 00
[   26.759079] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759080] sd 3:0:0:0: [sdd]
[   26.759082] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759083] sd 3:0:0:0: [sdd] CDB:
[   26.759086] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759088] sd 3:0:0:0: [sdd]
[   26.759089] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759091] sd 3:0:0:0: [sdd] CDB:
[   26.759084] Read(10): 28
[   26.759092] Read(10): 28 00 00 00 08 08 00 00 08 00
[   26.759104]  00 00 03 28 00 00 00 08 00
[   26.759114] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759116] sd 3:0:0:0: [sdd]
[   26.759117] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759118] sd 3:0:0:0: [sdd] CDB:
[   26.759118] Read(10): 28 00 00 00 08 08 00 00 08 00
[   26.759124] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759132] sd 3:0:0:0: [sdd]
[   26.759134] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759135] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759136] sd 3:0:0:0: [sdd]
[   26.759138] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759139] sd 3:0:0:0: [sdd] CDB:
[   26.759144] sd 3:0:0:0: [sdd] CDB:
[   26.759141] Read(10): 28 00
[   26.759145] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759159]  00 00 08 08 00 00 08 00
[   26.759176] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759177] sd 3:0:0:0: [sdd]
[   26.759178] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759180] sd 3:0:0:0: [sdd] CDB:
[   26.759181] Read(10): 28 00 00 00 08 08 00 00 08 00
[   26.759186] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759188] sd 3:0:0:0: [sdd]
[   26.759189] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759191] sd 3:0:0:0: [sdd] CDB:
[   26.759197] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759198] sd 3:0:0:0: [sdd]
[   26.759199] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759201] sd 3:0:0:0: [sdd] CDB:
[   26.759192] Read(10): 28 00 00 03 28 00 00 00
[   26.759202] Read(10): 28 00 00 00 08 18 00 00 08 00
[   26.759215]  08 00
[   26.759224] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759225] sd 3:0:0:0: [sdd]
[   26.759226] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759227] sd 3:0:0:0: [sdd] CDB:
[   26.759228] Read(10): 28 00 00 00 08 18 00 00 08 00
[   26.759251] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759252] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759255] sd 3:0:0:0: [sdd]
[   26.759256] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759258] sd 3:0:0:0: [sdd] CDB:
[   26.759263] sd 3:0:0:0: [sdd]
[   26.759264] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759266] sd 3:0:0:0: [sdd] CDB:
[   26.759259] Read(10): 28 00
[   26.759267] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759280]  00 00 08 18 00 00 08 00
[   26.759295] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759299] sd 3:0:0:0: [sdd]
[   26.759300] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759302] sd 3:0:0:0: [sdd] CDB:
[   26.759302] Read(10): 28 00 00 00 08 18 00 00 08 00
[   26.759309] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759312] sd 3:0:0:0: [sdd]
[   26.759313] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759314] sd 3:0:0:0: [sdd] CDB:
[   26.759315] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759340] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759342] sd 3:0:0:0: [sdd]
[   26.759343] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759344] sd 3:0:0:0: [sdd] CDB:
[   26.759345] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759360] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759363] sd 3:0:0:0: [sdd]
[   26.759364] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759366] sd 3:0:0:0: [sdd] CDB:
[   26.759367] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759382] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759383] sd 3:0:0:0: [sdd]
[   26.759384] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759385] sd 3:0:0:0: [sdd] CDB:
[   26.759385] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759397] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759399] sd 3:0:0:0: [sdd]
[   26.759399] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759401] sd 3:0:0:0: [sdd] CDB:
[   26.759401] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759414] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759415] sd 3:0:0:0: [sdd]
[   26.759416] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759417] sd 3:0:0:0: [sdd] CDB:
[   26.759417] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759432] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759433] sd 3:0:0:0: [sdd]
[   26.759435] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759436] sd 3:0:0:0: [sdd] CDB:
[   26.759437] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759450] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759451] sd 3:0:0:0: [sdd]
[   26.759452] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759453] sd 3:0:0:0: [sdd] CDB:
[   26.759454] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759465] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759467] sd 3:0:0:0: [sdd]
[   26.759468] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759469] sd 3:0:0:0: [sdd] CDB:
[   26.759469] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759481] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759482] sd 3:0:0:0: [sdd]
[   26.759483] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759484] sd 3:0:0:0: [sdd] CDB:
[   26.759485] Read(10): 28 00 00 03 28 00 00 00 08 00
[   26.759501] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759503] sd 3:0:0:0: [sdd]
[   26.759504] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759505] sd 3:0:0:0: [sdd] CDB:
[   26.759506] Read(10): 28 00 00 03 28 08 00 00 08 00
[   26.759518] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759519] sd 3:0:0:0: [sdd]
[   26.759520] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759521] sd 3:0:0:0: [sdd] CDB:
[   26.759522] Read(10): 28 00 00 03 28 08 00 00 08 00
[   26.759533] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759534] sd 3:0:0:0: [sdd]
[   26.759535] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759536] sd 3:0:0:0: [sdd] CDB:
[   26.759537] Read(10): 28 00 00 03 28 08 00 00 08 00
[   26.759579] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759581] sd 3:0:0:0: [sdd]
[   26.759582] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759584] sd 3:0:0:0: [sdd] CDB:
[   26.759585] Read(10): 28 00 00 03 28 08 00 00 08 00
[   26.759598] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759599] sd 3:0:0:0: [sdd]
[   26.759600] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759602] sd 3:0:0:0: [sdd] CDB:
[   26.759602] Read(10): 28 00 00 03 28 18 00 00 08 00
[   26.759614] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759615] sd 3:0:0:0: [sdd]
[   26.759616] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759617] sd 3:0:0:0: [sdd] CDB:
[   26.759618] Read(10): 28 00 00 03 28 18 00 00 08 00
[   26.759633] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759635] sd 3:0:0:0: [sdd]
[   26.759637] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759638] sd 3:0:0:0: [sdd] CDB:
[   26.759639] Read(10): 28 00 00 03 28 18 00 00 08 00
[   26.759653] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759654] sd 3:0:0:0: [sdd]
[   26.759655] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   26.759656] sd 3:0:0:0: [sdd] CDB:
[   26.759657] Read(10): 28 00 00 03 28 18 00 00 08 00
[   26.759669] sd 3:0:0:0: [sdd] Unhandled error code
[   26.759671] sd 3:0:0:0: [sdd]
removed due to length
[   27.676174] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676175] sd 3:0:0:0: [sdd] CDB:
[   27.676175] Read(10): 28 00 00 00 08 08 00 00 08 00
[   27.676216] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676217] sd 3:0:0:0: [sdd]
[   27.676218] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676220] sd 3:0:0:0: [sdd] CDB:
[   27.676220] Read(10): 28 00 00 00 08 00 00 00 08 00
[   27.676285] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676286] sd 3:0:0:0: [sdd]
[   27.676287] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676289] sd 3:0:0:0: [sdd] CDB:
[   27.676289] Read(10): 28 00 38 91 07 80 00 00 08 00
[   27.676312] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676314] sd 3:0:0:0: [sdd]
[   27.676315] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676321] sd 3:0:0:0: [sdd] CDB:
[   27.676321] Read(10): 28 00 38 91 07 f0 00 00 08 00
[   27.676347] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676349] sd 3:0:0:0: [sdd]
[   27.676350] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676352] sd 3:0:0:0: [sdd] CDB:
[   27.676352] Read(10): 28 00 00 03 28 00 00 00 08 00
[   27.676377] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676378] sd 3:0:0:0: [sdd]
[   27.676379] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676381] sd 3:0:0:0: [sdd] CDB:
[   27.676381] Read(10): 28 00 00 03 28 08 00 00 08 00
[   27.676423] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676425] sd 3:0:0:0: [sdd]
[   27.676426] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676427] sd 3:0:0:0: [sdd] CDB:
[   27.676428] Read(10): 28 00 00 03 28 00 00 00 08 00
[   27.676492] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676494] sd 3:0:0:0: [sdd]
[   27.676495] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676496] sd 3:0:0:0: [sdd] CDB:
[   27.676497] Read(10): 28 00 3a 35 1f 80 00 00 08 00
[   27.676521] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676523] sd 3:0:0:0: [sdd]
[   27.676524] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676525] sd 3:0:0:0: [sdd] CDB:
[   27.676526] Read(10): 28 00 3a 35 1f f0 00 00 08 00
[   27.676549] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676551] sd 3:0:0:0: [sdd]
[   27.676552] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676553] sd 3:0:0:0: [sdd] CDB:
[   27.676553] Read(10): 28 00 38 91 08 00 00 00 08 00
[   27.676576] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676578] sd 3:0:0:0: [sdd]
[   27.676579] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676580] sd 3:0:0:0: [sdd] CDB:
[   27.676580] Read(10): 28 00 38 91 08 08 00 00 08 00
[   27.676621] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676622] sd 3:0:0:0: [sdd]
[   27.676623] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676624] sd 3:0:0:0: [sdd] CDB:
[   27.676625] Read(10): 28 00 38 91 08 00 00 00 08 00
[   27.676690] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676692] sd 3:0:0:0: [sdd]
[   27.676693] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676694] sd 3:0:0:0: [sdd] CDB:
[   27.676695] Read(10): 28 00 3a 38 57 80 00 00 08 00
[   27.676718] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676720] sd 3:0:0:0: [sdd]
[   27.676721] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676722] sd 3:0:0:0: [sdd] CDB:
[   27.676722] Read(10): 28 00 3a 38 58 20 00 00 08 00
[   27.676746] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676747] sd 3:0:0:0: [sdd]
[   27.676748] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676749] sd 3:0:0:0: [sdd] CDB:
[   27.676750] Read(10): 28 00 3a 35 20 00 00 00 08 00
[   27.676773] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676774] sd 3:0:0:0: [sdd]
[   27.676775] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676776] sd 3:0:0:0: [sdd] CDB:
[   27.676777] Read(10): 28 00 3a 35 20 08 00 00 08 00
[   27.676817] sd 3:0:0:0: [sdd] Unhandled error code
[   27.676819] sd 3:0:0:0: [sdd]
[   27.676820] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[   27.676821] sd 3:0:0:0: [sdd] CDB:
[   27.676822] Read(10): 28 00 3a 35 20 00 00 00 08 00
[   29.040048] Adding 3998716k swap on /dev/sdc5.  Priority:-1 extents:1 across:3998716k
[   29.049544] EXT4-fs (sdc6): re-mounted. Opts: (null)
[   29.252501] EXT4-fs (sdc6): re-mounted. Opts: errors=remount-ro
[   29.318326] loop: module loaded
[   33.757778] r8169 0000:02:00.0: firmware: agent loaded rtl_nic/rtl8168f-1.fw into memory
[   33.878195] r8169 0000:02:00.0 eth1: link down
 Post subject: Re: Failed Seagate ST9500420AS
PostPosted: August 19th, 2013, 16:50
With smartmontools I get this. I don't know if I have the device type right, but this seems to be the only way to get any information out of it.
root@Forty-Two:~# smartctl --xall -r ioctl,2 -d ata -T verypermissive -s on /dev/sdd
smartctl 5.41 2011-06-09 r3365 [x86_64-linux-3.7-trunk-amd64] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
REPORT-IOCTL: Device=/dev/sdd Command=IDENTIFY DEVICE
Input:   FR=...., SC=0x01, LL=...., LM=...., LH=...., DEV=...., CMD=0xec IN
REPORT-IOCTL: Device=/dev/sdd Command=IDENTIFY DEVICE returned -1 errno=5 [Input/output error]
===== [IDENTIFY DEVICE] DATA START (BASE-16) =====
000-015: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
016-031: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
032-047: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
048-063: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
064-079: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
080-095: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
096-111: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
112-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
128-143: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
144-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
160-175: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
176-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
192-207: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
208-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
224-239: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
240-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
256-271: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
272-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
288-303: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
304-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
320-335: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
336-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
352-367: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
368-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
384-399: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
400-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
416-431: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
432-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
448-463: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
464-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
480-495: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
496-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
===== [IDENTIFY DEVICE] DATA END (512 Bytes) =====
REPORT-IOCTL: Device=/dev/sdd Command=IDENTIFY PACKET DEVICE
Input:   FR=...., SC=0x01, LL=...., LM=...., LH=...., DEV=...., CMD=0xa1 IN
REPORT-IOCTL: Device=/dev/sdd Command=IDENTIFY PACKET DEVICE returned -1 errno=5 [Input/output error]
===== [IDENTIFY PACKET DEVICE] DATA START (BASE-16) =====
===== [IDENTIFY PACKET DEVICE] DATA END (512 Bytes) =====
Smartctl: Device Read Identity Failed: Input/output error
=== START OF INFORMATION SECTION ===
Device Model:     [No Information Found]
Serial Number:    [No Information Found]
Firmware Version: [No Information Found]
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   [No Information Found]
ATA Standard is:  [No Information Found]
Local Time is:    Mon Aug 19 15:36:32 2013 CDT
SMART support is: Ambiguous - ATA IDENTIFY DEVICE words 82-83 don't show if SMART supported.
SMART support is: Ambiguous - ATA IDENTIFY DEVICE words 85-87 don't show if SMART is enabled.
                  Checking to be sure by trying SMART RETURN STATUS command.
REPORT-IOCTL: Device=/dev/sdd Command=SMART STATUS
Input:   FR=0xda, SC=...., LL=...., LM=0x4f, LH=0xc2, DEV=...., CMD=0xb0
REPORT-IOCTL: Device=/dev/sdd Command=SMART STATUS returned -1 errno=5 [Input/output error]
SMART support is: Unknown - Try option -s with argument 'on' to enable it.
=== START OF ENABLE/DISABLE COMMANDS SECTION ===
REPORT-IOCTL: Device=/dev/sdd Command=SMART ENABLE
Input:   FR=0xd8, SC=...., LL=0x01, LM=0x4f, LH=0xc2, DEV=...., CMD=0xb0
REPORT-IOCTL: Device=/dev/sdd Command=SMART ENABLE returned -1 errno=5 [Input/output error]
Error SMART Enable failed: Input/output error
Smartctl: SMART Enable Failed.
SMART Disabled. Use option -s with argument 'on' to enable it.
root@Forty-Two:~#
PostPosted: August 19th, 2013, 17:47
Head crash with media damage. The more you work with it, the less chance of recovery.
http://www.datasaversllc.com
PostPosted: August 19th, 2013, 18:51
Agree that the extend of the problem might increase with the new attempts, so if your data is important get a pro to analyze it for it.
PostPosted: August 19th, 2013, 19:00
So I am looking at over $500 for recovery? There is a cleanroom at my university, head crash is just simply replacing or resetting the head. How hard is it to repair media damage on the platter?
PostPosted: August 19th, 2013, 19:13
Well, I think first of all you should make some reading here about the kind of problem that your drive suffers.
The cleanroom may help you to open the drive safely, but it will not "insert" the know-how into your head on how to swap heads or even deal with media damage, as that is even a totally different story.
If I were you, first of all, get a quote from a pro. If the data is not worth that amount, open the drive in the cleanroom and just take some pictures and post here, so anyone can check it.
But remember the story about the screw, the biggest amount paid is not to tight the screw, but to know which screw to tight.
PostPosted: August 19th, 2013, 19:31
Maybe I'm just arrogant, but I really think I could manage if I do research.
Any ideas on where I can send it?
I'm just looking for simple service, I don't care how long it takes or extra services.
If I can just get a clone or enough raw data to re-create the drive that would be good enough for me.
PostPosted: August 19th, 2013, 19:34
I do believe that research is just a part of the effort, then you need practice.
Jon is from Atlanta, but might be even some other pro member from Texas.
You can confirm the conditions with them.
PostPosted: August 19th, 2013, 19:36
Thanks for the input. Guess I will be lurking around the forums then. :D
PostPosted: August 19th, 2013, 23:23
8/9 out of 10 it is beyond repair NOW, in any case no DIY . The HDD is not ID'ing itself anymore.
P.s. Depending on damage the new headset will be killed in seconds at powerup or when the damaged area is reached.
PostPosted: August 20th, 2013, 3:01
Pro's correct me if I am wrong, but you don't and can't repair media damage on the platter, you get the data off in spite of the damage? even if you could repair the damage, how would you put the data on there?
PostPosted: August 21st, 2013, 3:35
Whatever data was there prior to media damage, it is now on the filter. Unless someone can reconstruct dust, it's just dust now.
Users browsing this forum: No registered users and 65 guests
