 Post subject: PCB swap best practice
PostPosted: August 25th, 2013, 12:21
What should I do with Firmware Repair Tools before triyng the pcb swap on a faulty drive:
Clear G-List on the working pcb or what other ?
Bye
 Post subject: Re: PCB swap best practice
PostPosted: August 26th, 2013, 5:13
I think you should be reading firstly a bit about the difference between PCB and FW (SA), because this are 2 different things.
What do you need to do?
PostPosted: August 26th, 2013, 7:14
Ok, I'll try to explain:
does the firmware chip on pcb contains some bad sector data (or other information) that should be cleared via software before swapping the pcb?
PostPosted: August 26th, 2013, 7:31
There are other details to be concerned with when swapping PCBs, but to answer the question: no.
PostPosted: August 26th, 2013, 7:45
Here you have your answer.
PostPosted: August 26th, 2013, 9:34
This means that I should only clear bad sector data from firmware chip, in some way via softare ?
PostPosted: August 26th, 2013, 12:43
You don't need to clear any data on the ROM chip...
The G-list is on the platter inside the drive...@ the SA (Service Area)
What is the problem with the drive? Clicks, not visible, stone dead?
http://www.rescue-it.se
Users browsing this forum: fouad19764, Google [Bot] and 200 guests
