ST3500320NS 0 LBA
August 26th, 2013, 14:28
hi,
after translator regenerate things finishes immediately but problem still persists
it seems nothing is being done inside after the command.
check the attached log and advice pls
LOG.rar
(1009 Bytes) Downloaded 379 times
Re: ST3500320NS 0 LBA
August 26th, 2013, 16:44
It's found that, some modules can't be read.
May be SA Bad sector or CORRUPT module.
All CP(ROM) & (RAM) can be read
Following modules can't be read ---
000A
000B
0015
0019
0027
0030
0035
003A
ST3500320NS
FW: SN06
SN: 9QMXXXXX
Share me the FW if you have in stock please.
Do you think, any above modules associated with the problem?
August 27th, 2013, 4:06
Update:
After regen, when double clicking on PARAMETERS BAR, then Full capacity appears. but in sector view all 6666.
After power reset, capacity again to 0 LBA
August 27th, 2013, 7:58
What are the function of these 2 modules?
0019?
0035?
