 Post subject: ST3500320NS 0 LBA
PostPosted: August 26th, 2013, 14:28
hi,
after translator regenerate things finishes immediately but problem still persists
it seems nothing is being done inside after the command.
check the attached log and advice pls
LOG.rar [1009 Bytes]
Downloaded 380 times
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: ST3500320NS 0 LBA
PostPosted: August 26th, 2013, 16:44
It's found that, some modules can't be read.
May be SA Bad sector or CORRUPT module.
All CP(ROM) & (RAM) can be read
Following modules can't be read ---
000A
000B
0015
0019
0027
0030
0035
003A
ST3500320NS
FW: SN06
SN: 9QMXXXXX
Share me the FW if you have in stock please.
Do you think, any above modules associated with the problem?
__________
THANK YOU
SHAHI
PostPosted: August 27th, 2013, 4:06
Update:
After regen, when double clicking on PARAMETERS BAR, then Full capacity appears. but in sector view all 6666.
After power reset, capacity again to 0 LBA
__________
THANK YOU
SHAHI
PostPosted: August 27th, 2013, 7:58
What are the function of these 2 modules?
0019?
0035?
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 33 guests
