 Post subject: SA BAD in Seagate HDD
PostPosted: August 27th, 2013, 6:27
This is a case associated with a case 0 LBA problem in a ES.2 drive. The same can happen to other drives also, may be many of you faced already or not.
Whenever BAD Sector is developed in SA of Seagate F3 or previous series, anyone have been able to work successfully?
There is a method is seen about WD Module relocation to good areas instead of bad areas. Is there any way to get around on Seagate HDD SA while Bad Sectors on SA?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
