 Post subject: MyBook USB Encryption Details
PostPosted: August 30th, 2013, 12:29
Hi
Its good to be part of the forum. I am relatively new to DR and are learning loads from reading past posts. I have a question about the WD MyBook USB Encryption. I know the drive is encrypted through the USB board. So I guess if I recovered a drive using a DDI, the new drive would not read as the USB board is paired to the old drive, is that right?
If this is the case, am able to tack down a similar USB board and complete a chip swap to make it read? I only have the basic DDI, not the USB version.
 Post subject: Re: MyBook USB Encryption Details
PostPosted: August 30th, 2013, 12:38
there is not enough information provided to answer this question
you need to specify type of the USB chip and form factor of the drive
PostPosted: September 3rd, 2013, 14:14
This was more of a general question about the make up of the drive, rather than case specific. Are you saying in that case they are all different?
Users browsing this forum: Majestic-12 [Bot] and 47 guests
