 Post subject: WD40EZRZ-00WN9B0
PostPosted: September 25th, 2017, 13:57
Hello
The drive in topic is locked with ata password.
I can read FW modules but i can't find the password with normal method in mod. 02
Has anyone know in which module i can find the password?
MRT can't access the FW.
Thanks in advance.
 Post subject: Re: WD40EZRZ-00WN9B0
PostPosted: September 25th, 2017, 14:23
I have made a test with a working drive same family (Giant). And compared mod. 02 before and after lock, but the surprise is it's matched and identical with no differences.
PostPosted: September 25th, 2017, 17:45
Is it a SED?
Is there anything in modules 0x124 and 0x127?
got HW crypto? On the (in)security of a Self-Encrypting Drive series:
https://eprint.iacr.org/2015/1002.pdf
Facing a protected HDD is not new problem for HDD forensics. As there are already existing commercial solutions (e.g PC-3000), we analyzed the HDD directly with those tools. Their approach seems to follow a straight pattern, which allows SA access by overwriting the RAM/ROM and bypass security features like ATA passwords and optionally AES keys. By forcing SA access and manipulating the SA area 0x124 and 0x127 we were able to unlock the HDD and disable the SATA AES encryption. Note that this works always, independent of the chosen user password and bridge status.
PostPosted: September 25th, 2017, 18:02
Spildit wrote:
What tools are you using (and working) to read modules on the locked drive (as you stated MRT is not working) ?
Did you try to copy module 02 from unlocked drive to locked drive RAM ?
I have shorted tv9 and 10 before complete calibration to enable access to SA. Now i got a complete backup.
PostPosted: September 25th, 2017, 18:04
Is it a SED?
I will investigate those two mods tomorrow when i get to the office.
Thank you.
PostPosted: September 25th, 2017, 18:18
The attachment contains modules 02, 124, and 127 from the following resource dump:
http://files.hddguru.com/viewer_top.php?file=WDC%20WD40EZRZ-00WN9B0-80.00A80-WD-WCC4E1HDC2TE-0001008B.rar&dir=PC-3000-UDMA%20Support/WDC%20Marvell%20family%20utility/Giant
The SED flag in module 02 is set.
00000860                    00 00 00 00 00 00 01
WD40EZRZ.rar [1.45 KiB]
Downloaded 919 times
PostPosted: September 26th, 2017, 9:55
124 and 127 looks encrypted.
Overwrite those mods from unlocked drive will solve the problem?
PostPosted: September 26th, 2017, 10:25
Thank you all.
Solved
PostPosted: September 26th, 2017, 17:55
Please, tell us what was the solution.
PostPosted: September 27th, 2017, 9:13
It is amazing how people can ask for advice on how to do something, but when they get it figured out, they don't want to share how they did it. It should become a forum policy that if you ask a question on this forum and figure it out, you are committed to post the solution. That said, let's give the OP a little time to respond to your request.
PostPosted: September 27th, 2017, 11:48
I have send a pm to him with the solution.
Any way, i have cleared mod. 127 that's all
Users browsing this forum: No registered users and 68 guests
