buffalo ministation hd-pc1tu2 not working
September 9th, 2013, 8:15
HI,
can someone help me with restoring my hard drive, I have a buffalo ministation hd-pc1tu2, which every time i plug into my PC, it makes a noise and then it stops working.
because of this situation i can not format the hard disk or even open it to see what the issue is.
if anyone know how i will able to format or restore my Hard disk, please let me know
thanks
anish327
Re: buffalo ministation hd-pc1tu2 not working
September 9th, 2013, 8:58
Can you describe the noise in more detail? Also, what is happening with the computer when connecting the Buffalo?
September 9th, 2013, 10:42
all it does is beeps 5-10 times and then completely turns off. nothing happens to the PC, it does not recognize it. and i also i tried to connect it with another pc and the same thing happen.
anything you can help me with?
anish327
September 9th, 2013, 19:31
Any chance it may have been dropped or sustained some sort of shock?
September 10th, 2013, 2:22
I would imagine it has, sometimes it doesn't take a lot.
From the sounds of it, it's a physical issue and not dot. Sorry
