 Post subject: Samsung - common PCB problem
PostPosted: September 2nd, 2013, 6:47
I receive many Samsung drives with dead pcb.
Usually transil diodes or 0 ohm resistors are ok.
Whats their Achilles heel from your experience ?
data recovery Poland
 Post subject: Re: Samsung - common PCB problem
PostPosted: September 2nd, 2013, 9:38
I would say users :mrgreen:
PostPosted: September 3rd, 2013, 5:54
excluding users influence ?
PostPosted: September 3rd, 2013, 6:03
I think that's very hard to say, because that might be due to problems on the electric installations of buildings, on the computers PSU's and might not be even a big issue with the drives itself.
That's why I think that's really hard to say.
PostPosted: September 3rd, 2013, 7:46
A quick check of the onboard power supplies should take 2 minutes. That should tell you whether the motor controller is at least partially functional.
PostPosted: September 5th, 2013, 4:18
In all cases only pcb is damaged
PostPosted: September 19th, 2013, 23:00
Boss, FZABKAR
would u please please & please explain how to do it.
If you explain thousands of uses will be benefited.
advanced thanx.
PostPosted: September 20th, 2013, 2:21
70% user 30% seems fatality.
P.s. In thousands seen for recovery / refurb no more than 10 had TVS problems.
PostPosted: September 20th, 2013, 2:55
Tutorial - how to locate the basic test points of an unfamiliar HDD PCB:
http://www.users.on.net/~fzabkar/HDD/Tu ... 0411N.html
HDD TVS diode FAQ:
http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
Tutorial - Linear and Switchmode Regulators used in HDDs:
http://malthus.zapto.org/viewtopic.php?f=59&t=231&p=597
@longlife, if you have a specific PCB, I can show you what and where to measure.
Users browsing this forum: gps31 and 75 guests
