 Post subject: WD My Passport 1 TB
PostPosted: September 8th, 2013, 23:29
Hi I just dropped my WD My Passport 1TB hard drive to floor while it's working and now it's not working. When I plug in the usb cable the hard drive clicks periodically every 5 seconds. The drive doesn't show up in Computer and I don't know if it shows up in BIOS. I have some personal info in it and I'd like a way to recover it. Do you think the drive is recoverable? If yes what should my next step be?
Model : WD My Passport 1TB Portable External Hard Drive Storage USB 3.0 Black
 Post subject: Re: WD My Passport 1 TB
PostPosted: September 9th, 2013, 1:36
COntact Professional Recovery Company ..................
PostPosted: September 9th, 2013, 3:20
Exactly so, nothing you can do DIY :-(
PostPosted: September 9th, 2013, 9:04
It may be recoverable. All depends on the physical damage extent.
No longer connect it so that it is no longer powered on. The more it is powered on, then more reducing chances of recovery.
As suggested before, to maximize chances of recovery, a data recovery specialist in the best course of action. Why? Well, the architecture of the device is complex in nature requiring advanced skills in properly evaluating the failure(s) and thereafter implementing the correct procedure toward recovering the data.
PostPosted: September 9th, 2013, 17:20
If the drive doesn't spin, then it could be a stiction fault (heads stuck to platters), with possible head/media damage. If it spins and clicks, then it has most probably sustained head and/or media damage.
See download/file.php?id=7003
Users browsing this forum: No registered users and 14 guests
