WD passport connects pc shows initio default controller
September 9th, 2013, 9:04
i've upgraded the firmware, after that the drive stopped appearing in My computer, Disk Management and device manager.
plug in usb port,it installs a driver shows that its initio default controller.
how to solve it?
thanks a lot......
Re: WD passport connects pc shows initio default controller
September 9th, 2013, 9:06
What prompted you to update the firmware?
September 9th, 2013, 9:15
a doings of ghosts and gods :cry:
September 9th, 2013, 10:13
I had this before.
I converted to SATA, cloned and decrypted clone
September 9th, 2013, 18:30
Does the drive still spin up?
Have you tried updating the firmware again?
According to various threads at WD's and Seagate's forums , the "Initio Default Controller" ID can occur if the drive's serial EEPROM is corrupt or cannot be detected, or if the drive is not getting sufficient power from the USB port.
The bridge IC also IDs this way when it is preparing itself to receive a firmware download.
September 9th, 2013, 23:13
fzabkar wrote:Does the drive still spin up?
Yes , it still spins when i plug it in to PC , but it cannot be detected by WD updating software , even in Disk Management , so that i can't do anything to it through a PC now... :cry:
September 10th, 2013, 18:38
How does UVCView or USBDeview detect your drive?
http://www.nirsoft.net/utils/usb_devices_view.html
http://malthus.zapto.org/viewtopic.php?f=36&t=174
September 10th, 2013, 20:12
jeez Franc, I searched for that tool after you mentioned it to add the info to my USB research. I searched the net and all links came up dead, so I stuck with Nirs tool and the MSInfo32. And it has been here all along.. doh!
September 10th, 2013, 20:32
UVCView is a Microsoft tool. For some inexplicable reason, Microsoft pulled it from its web site many years ago. I've been making it available from my own web space since then.
There was an earlier tool called USBView which shipped on Microsoft's Windows 98 CD.
http://msdn.microsoft.com/en-us/library ... 19(v=vs.85).aspx
BTW, this seems like a good resource:
http://www.lvr.com/development_tools.htm
