 Post subject: Is It possible to swap this maxtor slim
PostPosted: August 9th, 2007, 13:11
Hi folks.. :D
need some help here..
come to me, Maxtor DM 8S ( SATA150 HDD ) with spindle seizure. the spindle cannot be move at all.. even when try to push it harder.. I need to get the data out.. since I don't have any suitable donor..
Is It possible to swap platter from : :?
HDD : Maxtor Diamond Max 8S SATA150HDD, 40GB, Serial ATA
code : NAN51680, 6N040T0, KMBA
with this Good donor :
HDD : Maxtor Diamond Max Plus 8, ATA, 40GB
code : NAR61HA0, 6E040L0, KMCA
Hopefully anyone have experience in this kind of SATA drive can make an advice for me... :wink:
 Post subject: Re: Is It possible to swap this maxtor slim
PostPosted: August 10th, 2007, 10:57
anybody ??
PostPosted: August 10th, 2007, 11:11
I've never even seen SATA N40Ps. You are lucky :)
PostPosted: August 10th, 2007, 12:53
thanks starling for your respon...
:lol: yup.. I only seen this time..
successfull data recovery. got 100% of the data out.
seem like.. nothing problem beside the spindle motor stuck.
change the motor with another motor from maxtor N40P. and than problem solve... :lol:
PostPosted: August 10th, 2007, 14:36
is the HDA different than that of the N40P? Just because U didn't simply swap the platter...
thx,
PostPosted: August 12th, 2007, 6:08
The SATA versions look the same as the PATA version (Using the bosy of the calypso) from my memory
Quite rare but I have a few
A man is as old as he feels, and a woman as old as she looks
PostPosted: August 14th, 2007, 11:47
Hi pepe, hddguru.
I try to swap the platter, but it seems like the head doesn't want to read the SA ( just swinging ). Why this happen ?
is there a big different between SATA and PATA SA ?
PostPosted: October 17th, 2013, 1:27
Never mind, I figured out.
It is a Maxtor 40GB DiamondMax Plus 8 NAR61HA0
Thanks anyway since the NAR61HA0 code helped me.
Cheers!
