 Post subject: Samsung 1tb; PCB ok, head ok, no access!!!
PostPosted: January 17th, 2012, 7:46
Hello friends.
Do you know any solution for this error?
*PA VID=0000 PN=0004 Rev=0002- 785x Found002- 785x Found
*PA VID=0000 PN=0004 Rev=0002- 785x Fou *PA VID=0000 PN=0004 Rev
nd
ChipRev = 63B0
=0002-
U
S_0
RV En Sensor Circuit
En Shock Sensor Circuit U
SO_1
SpinStartUp: mcSpinRPM = 0En Sensor Circuit
RPM at Handoff: 588 Sensor Circuit
Temp : 28 degC
SO_1
Sp
SpinOkUp: mc
mS1 00000003
SK C:111981 H:0 at Handoff: 58
POK
POK
Boot Sector Error! Take a default.
SpinOk
mS1 00000003
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x14
Selective MARC NX Loaded
ResoTable Loaded. Rev:0x01
Ovly loaded to 0x0001CD00
Ovly loaded to 0x1005B800
FdtTable Load
Hd: 0 Zn: 1 Avg.: 51
SVCAL(0080,0000)-->PASS
| 147 | IN_SITU | 20 | 0 | 836 | 1140 |
>>InsituStart: t=1285, c=29
| 249 | NINSITUL | 45 | 0 | 2 | 1140 |
GeoId = 49, Idx=49
fodstep: 00000069 dgain: 0000007E
GeoId = 49, Idx=49
fodstep: 0000006C dgain: 00000089
GeoId = 49, Idx=49
fodstep: 0000006D dgain: 00000085
GeoId = 49, Idx=49
fodstep: 00000065 dgain: 0000005A
GeoId = 49, Idx=49
fodstep: 00000072 dgain: 00000061
GeoId = 49, Idx=49
fodstep: 0000007A dgain: 0000005E
GeoId = 49, Idx=49
fodstep: 0000006A dgain: 0000005E
GeoId = 49, Idx=49
fodstep: 00000072 dgain: 00000066
GeoId = 49, Idx=49
fodstep: 00000075 dgain: 00000064
GeoId = 49, Idx=49
fodstep: 0000005F dgain: 0000006A
GeoId = 49, Idx=49
fodstep: 0000006B dgain: 00000072
GeoId = 49, Idx=49
fodstep: 00000071 dgain: 0000006D
EPOK
W-MC e(00007704) (20: 0: 864:0x08:0x003F)
EPOK
>>Flag=0000028B BadHd=0001 dFod=0019 001E 0019 0015 (t=2479 c=28)
| 244 | ZONHEAL2 | 43 | 0 | 0 | 1140 |
| 167 | DRM | 33 | 0 | 0 | 1140 |
[DEBUG HALT @MDL_RSRC_BufferAlloc():10034A21 L0 1005BDB3]
[DEBUG HALT @MDL_RSRC_BufferAlloc():10034A21 L0 0000EC77]
[DEBUG HALT @MDL_RSRC_BufferAlloc():10034A44 L0
[DEBUG HALT @tProfile():10034A21 L0 0000EC77]
Cur_SP=04005D20
FIQ_SP=04005D20
IRQ_SP=04005D20
SVC_SP=04005D20
*** HALT ***
Thanks to those who help.
 Post subject: Re: Samsung 1tb; PCB ok, head ok, no access!!!
PostPosted: January 17th, 2012, 9:19
Hello!!
Verify modules!! :idea:
Нет ничего невозможного
PostPosted: January 17th, 2012, 9:54
have some alternative way, without being with UDMA?
PostPosted: September 22nd, 2013, 8:55
did you get the solution yet?
I have a same error with HD503HI.
Always BSY.
also added terminal log...
INCREASE A SECTOR SIZE IN MC!
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: September 22nd, 2013, 9:39
FULL LOG is attached... Please advice.
LOG.zip [923 Bytes]
Downloaded 374 times
__________
THANK YOU
SHAHI
PostPosted: September 23rd, 2013, 0:47
Write your own software.
P.s. Either the pcb is not native or someone played hard with firmware or ROM (OR used non native PCB) ?
PostPosted: September 23rd, 2013, 3:32
The PCB is native. 100% confirm. Nothing has been done. After the loss, the drive came directly to me.
The drive is always busy. Got access to SA by HotSwap. Smart Reset, A-list clear. Here is SAME LOG even after doing this so.
Now, I will have to check whole SA. Do you still have any idea now?
__________
THANK YOU
SHAHI
PostPosted: September 23rd, 2013, 9:48
I'm missing something : hugov and shahij are then actually the same person or same case ?
PostPosted: September 24th, 2013, 12:37
Hey BLACK, I think, you didn't read the post completely... he posted jan12 and I did in last 3 days... his case is 1TB but my case is 500GB (HD500HI).
Anyway, do you have any clue or explanation regarding the case? I would be happy if you like to share or also you can PM me to avoid public...
FYI: The HDD failed during a DATA CONVERSION of SQL database. Suddenly the HDD stopped/PC shut off and the user didn't get the drive detected anymore and sent to me directly for the recovery.
__________
THANK YOU
SHAHI
