 Post subject: Seagate 7200.12 ST31000528AS HP35 Help!
PostPosted: August 14th, 2014, 12:25
The HDD for our company that carries quite a bit of data went down.
7200.12
ST31000528AS
Firmware HP35
S/N 9VPA3FDA
Bios stopped recognizing and we researched, etc.
Passed spin up and spin down.
went through the entire process and the m0,2,2,,,,,22 command left me with a string of repeating errors.
Hooked it up againand it started clicking - something it hadn't done before.
Popped the top just to take a peek and noticed a small 1/8th inch scratch on the top platter. Applyed power just to observe spin up and when the head moves it squeals like crazy.
CLosed it back up and now here it sits on my desk.....Need some HELP!!!
 Post subject: Re: Seagate 7200.12 ST31000528AS HP35 Help!
PostPosted: August 14th, 2014, 14:04
Well, you opened your HDD... If you opened it in dirty enviroment (not super clean) then you will probably have big problem + that small scratch is even bigger problem. Then you used dangerous (for 7200.12 HDDs, there are LOTs of threads where guys say that it is dangerous) m0,2,2,,,,,22 command. Take it to DR Pro before you destroy it completely (or already destroyed :? ), but I think this is going to be expensive.
PostPosted: August 14th, 2014, 16:13
environment was clean, so no worries there.
m0 command was never able to run as the drive quickly threw an error code and was part of modified instructions for this particular case.
I think there is still hope for this drive.
Just need some alternative advice.
PostPosted: August 14th, 2014, 16:16
Well done with clean enviroment :wink:
What does the terminal actually says ? Post whole log here, since start
PostPosted: August 15th, 2014, 5:59
You probably need heads replacement but maybe not enaugth because media scratch es a ver y big problem
Post log here
Can you up pics from scratch¿
PostPosted: August 18th, 2014, 13:36
Will upload log and pics in a day or two.
PostPosted: August 21st, 2014, 12:46
Ok here is the log from spin up and spin down.
This was previously successful.
But the final spin up where the error occurred is paired with some high pitched squeal sounds....not clicking, but squeaking/squealing as the drive attempts to spin.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.08.21 10:39:20 =~=~=~=~=~=~=~=~=~=~=~=
ASCII Diag mode
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
Elapsed Time 0.084 msecs
F3 2>U
HighPowerMode
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 22.109 secs
R/W Status 2 R/W Error 84150180
F3 2>z
Input_Command_Error
F3 2>Z
Spin Down Complete
Elapsed Time 10.508 secs
F3 2>U
HighPowerMode
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 28.993 secs
F3 2>
PostPosted: August 21st, 2014, 14:49
A good think to know is: "how and when did platter get scratch?"
My firmware database:
PostPosted: August 21st, 2014, 15:26
As of right now that is no issue.....The imperfection or scratch or whatever it is was on the platter when it was opened up.
Need to get two files and a folder off of this thing....
PostPosted: August 21st, 2014, 17:48
If scratch was on platter before opening it then means that something happened when the drive was running.
Maybe it was bumped while running or there were excessive vibration, or power supply issue which has reduced rotation speed and consequently less air flow that has made touch heads on platters, or simply heads got faulty.
However very likely now heads are faulty and need to be replaced, hoping that new heads set don't get damaged right away because of that scratch.
PostPosted: August 22nd, 2014, 3:09
You know why it squeals? It's because the platters get's more scratched...
It's end of DIY, expect very high cost for recover data from that drive.
Bosse
http://www.rescue-it.se
PostPosted: August 22nd, 2014, 3:35
No it was not clean. Recently someone posted some info about the size of particles that can damage a HDD. As the head flies over the disc around the same height as smoke particles, and bigger and you can get damage. You say the environment was clean. I don't know what that means but if not in a proper clean chamber, then I don't think it was clean *enough*
Why do I know it was not clean? because when the disc was scratched, it created particles. A very good DR Lab might be able to do a partial recovery. As stated, no DIY options here that I can see. I hope you can get some good results from them.
PostPosted: August 22nd, 2014, 4:00
HaQue wrote:
As the head flies over the disc around the same height as smoke particles ...
http://www.datarecoverytools.co.uk/data ... thead-gap/
A dust particle looks like Mt Everest when compared to the flying height of a disc head.
http://www.datarecoverytools.co.uk/wp-c ... height.gif
Users browsing this forum: Google [Bot], jimmydata and 48 guests
