 Post subject: 3 HDD in single Disk o
PostPosted: October 3rd, 2013, 5:07
i have:
- hp DL385 g7 server.
- with 3 HDD (each one is 300 GB)
- windows server 2008 r2
The problem is that all the 3 HDD are in single Disk (Disk 0) and i want every HDD to separate them to 3 Disks (Disk 0, 1, and 2) so i can make a mirror between (Disk 1 and 2).
thnx :)
 Post subject: Re: 3 HDD in single Disk o
PostPosted: October 3rd, 2013, 5:37
BACKUP EVERYTHING FIRST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
what is current functionality of server (AD, file sever, database server,...)
your drives are probably in HW RAID.
What is total capacity in disk manager(300GB, 600 or 900GB) depends on RAID type
If you wish to prepare server with one single drive and two drives in mirror
1. backup everything(create image)
2 in RAID configurator delete current RAID
and then do configuration you whish
I need more detail about everything
BR
PostPosted: October 4th, 2013, 11:48
Banned User
I'm not sure why 3 hdd shows as one, by right it should shown as different, did you check device manager?
Users browsing this forum: Majestic-12 [Bot] and 89 guests
