 Post subject: GPT Protected Partition
PostPosted: October 16th, 2013, 12:44
Hi, I took a damaged hard drive form a HP pavilion g7. Put it in an external and trying to recover some personal files. I pluged the external into another desktop with winXP 32bit. Under disk management it shows the HP drive as GPT Protected Partition. How can I remove the protection to explore the drive and recover what I need? Thanks.
 Post subject: Re: GPT Protected Partition
PostPosted: October 16th, 2013, 15:46
try it with Win7 not XP
good luck
PostPosted: October 16th, 2013, 16:25
Try Partition Find & Mount:
http://findandmount.com/
I suspect that PF&M will mount your NTFS/FAT32 volume without regard to the type of partitioning system. There may be a complication if the drive or volume is larger than 2TiB, though.
Users browsing this forum: Google [Bot] and 246 guests
