 Post subject: Seagate 7200.4 ST9320423AS - Rst 0x10M on terminal
PostPosted: October 24th, 2013, 17:16
I have broken disk Seagate 7200.4 ST9320423AS.
After normal connect and turn up disk I can hear very quiet noise, check attachment. Motor is working.
After connecting disk to terminal I have:
Rst 0x10M
ASCII Diag mode
ctrl+z
F3 T>V40
LED:000000CE FAddr:002935E7
Rst 0x10M
Is this electronic or physical issue.
File comment: disk noise after normal connect and turn up
disk noise.zip [112.97 KiB]
Downloaded 409 times
 Post subject: Re: Seagate 7200.4 ST9320423AS - Rst 0x10M on terminal
PostPosted: October 28th, 2013, 10:31
Rst 0x10M
ASCII Diag mode
ctrl+z
F3 T>V40
Rst 0x10M
maybe you should short read channel pins.
you can search this forum and find how to short read channel pins
upload your drive PCB pics on both side. some one can tell you the ocations of read channel pins on you PCB.
PostPosted: July 28th, 2014, 22:35
Hello Zbyszek,
I have exactly the same model, and the same problem, did you find some solution?
LED: 00000067 (when PCB is removed).
Rst 0x10M (When PCB is on HDD)
Users browsing this forum: No registered users and 333 guests
