 Post subject: SA FORMAT
PostPosted: October 27th, 2013, 1:54
HI,
can any body tell me why we run SA FORMAT or FORMAT RESERVED AREA or SELF SA. and what we do after doing this ?
is there any one who tell me correct answer ?
i know its answer but want to know who already know it.
thanks
Waqas Ali
waqasali766@hotmail.com
 Post subject: Re: SA FORMAT
PostPosted: October 27th, 2013, 2:53
quiz master bhi!!!!!!!!!!!!!!!!
Thanks. This is the way how threads can be made very much interactive.
PostPosted: October 27th, 2013, 3:10
yes this is my way of training .
PostPosted: October 27th, 2013, 8:17
What is the prize if it is actually a quiz ?
PostPosted: October 27th, 2013, 8:18
PostPosted: October 27th, 2013, 9:14
its for knowladge base. i am waiting for a reply from one person then i post answer here with introduction.
PostPosted: October 27th, 2013, 10:15
Recognition in this forum, Do you want more than that?
PostPosted: October 27th, 2013, 11:06
waqas_ali766 wrote:
HI,
thanks
Waqas Ali
Everyone in DFL forum KNOWS about it, its there
PostPosted: October 27th, 2013, 12:26
i think the people who dont have dfl ,want to know about format sa and other function .
PostPosted: October 27th, 2013, 12:38
Money. This is what they want. :?
PostPosted: October 27th, 2013, 13:33
oh my friend . now i cannot say any thing here. the persons how want to know about this pm me . or mail me , i tell u the details
thanks
PostPosted: October 27th, 2013, 15:09
There are things money can't buy, for everything else there's a credit card.
Would be nicer to ask for a new section like QUIZZES , if the intent is genuine - start a question then when the correct answer is given, an explanation and the name of the 'winner' is given. Simple, isn't it?
PostPosted: October 28th, 2013, 4:54
HI,
sa format and reserved area format.
when we disable head in head map we need to remove its adaptives also and set the adaptives of head 1 to work like head 0. for example
head 0 701 adaptives
head 1 702 adaptives
head 2 703 adaptives
now we are going to disable head 0 in head map now these are the settings
head 1 701 adaptives
head 2 702 adaptives
703 adaptives
now here many user ignor the point and hdd start clicking after power reset . after disable we need to move adaptives like this
head 1 702
head 2 703
0
now after reset power hdd show ready and cannot spin down
now next thing is to change region so that hdd work with 2 heads , when 3 heads thee regions are 3, after disable heads regions are still 3 . now we need to remove region of head 0.
now in some hdd format sa or format reserved area need permanent overlay (module number 11) upload it and format SA after it complete see regions now there are 2 regions. if hdd has one head also have two regions. format sa also need a quick sa list and save error in this list ( module 35)
next step is to upload 01 directory module now people write 01 and 35 together but it is wrong . why they write together because when they write 01 module the 35 show header error.
solution
in wdr open modules operation and click on road map . here wirte 01 and initialize it now it cannot damaged 35 module. now write 11 module and initialize it . now close modules operation and open it again and write all modules except 01 and 35 now may people reset power and hdd goes undetected like mackenly and mariner hdd and also jamica. now after upload all modules select 31 32 33 34 36 modules and clear all these modules now reset power.
next step
reserved area arco .
after all these steps we need to run reserved arco to set all things with these two heads in rom .
SELF SA.
now after running arco we need to run self sa. what self sa do ? it add all bad sector from firmware are and add it into sa list (module 35) and also genrate new 30 module . now again we need to format sa with hdd own rp list (35 module) after that upload 01 and initialize it then write other except 01 and 35 .
and clear 31 32 33 34 36 modules . cannot clear 35 number module
now hdd is ready to start arco .
now it depend on u that u run arco one by one . or run arco in pst sequence.
. here is the procedure of recyling the hdd with head disabling .
head disable and head depop are two different things.
PostPosted: October 28th, 2013, 8:41
Thanx Mr. Ali. Though 90% went above my small head.
PostPosted: October 28th, 2013, 8:56
waqas_ali766 wrote:
HI,
I think more care should be considered with this type of info by always posting a disclaimer (your data will be destroyed!) with these type of descriptions. Why? Some people will erroneously think this will be a solution for data recovery, when it really is a solution for drive restoration/repair/etc.
PostPosted: October 28th, 2013, 9:32
no no its not for data recovery . if a person has a common sense then it read and think about format sa.
PostPosted: October 28th, 2013, 18:48
It is nothing to do with common sense.
If you are looking for information, really how do you draw the line between "I have found enough information for my particular application" and "I need to still gather more information"
such as people with 7200.12 and applying 7200.11 tutorial.
how many times have you been searching for information on something and realised afterwards you already had thi info, but didnt know how it linked with your problem, and also thought you knew something, tried a procedure and realised after that you stuffed up because you didnt know something?
It can happen to the most careful and clever people.
I would like to see people that do know something, and actually want to share, step into the shoes of the people that don't know.
for example :
answers like " you need to cannect sata to pcb" or "swap ROM and try it" etc
PostPosted: October 29th, 2013, 3:00
head depop is a function which a programer make . by using this option we select the head which we need to depop and it auto change all the thing like capacity, track density, adaptive, and many other thing.
but if we talk about head disable in rom map. then it is just head remove but in firmware all things are available for maximum heads, not for remaining heads.
so after head depop we need to set all thing manually,
PostPosted: October 29th, 2013, 4:49
Hi My All Dearest Gurus.
Can I Have Permission To Join This Hot Discussions. Lol
Yours Friend
Jignesh Pankhania
PostPosted: October 29th, 2013, 9:00
waqas_ali766 wrote:
head depop... auto change all the thing like capacity, track density, adaptive, and many other thing.
...so after head depop we need to set all thing manually,
Isn't this contradictory?
Users browsing this forum: Google [Bot] and 62 guests
