 Post subject: ReiserFS and Reiser4
PostPosted: November 7th, 2013, 17:58
Anyone know if any of the standard data recovery programs recover ReiserFs and Reiser4 File Systems? Perhaps R-Studio of UFS Explorer? I can only seem to get RAW recoveries.
 Post subject: Re: ReiserFS and Reiser4
PostPosted: November 7th, 2013, 20:41
What is the problem that you are trying to recover from?
PostPosted: November 8th, 2013, 11:45
I am a little confused by this one. I have an external hard drive that has been imaged and scanned through R-Studio. The scan does give me a green partition the same size as the original (and over 200 yellow). I have folder structure but the files are corrupt. Most of the partitions give me a EFI Sector label. I ran the drive through testdisk and it told me there was a ReiserFS partition.
PostPosted: November 8th, 2013, 12:49
UFS Explorer does work with ReiserFS
Angel Data Recovery
PostPosted: November 8th, 2013, 13:44
I tried UFS and it said the file system was unknown. I think it's basically full of corruption.
PostPosted: November 8th, 2013, 14:10
Did you get a 100% clean clone of the drive? Again, what was the original problem?
PostPosted: November 8th, 2013, 14:50
Original problem was a power surge. Imaged okay on the DDI except for 350 sectors (500 GB drive). So not entirely clean, but pretty close.
PostPosted: November 8th, 2013, 15:10
UFS explorer should be able to pick it up.
www.datarecoveryne.com
PostPosted: November 8th, 2013, 15:16
Bit more info: It was a single drive on a Simpleshare NAS.
PostPosted: November 8th, 2013, 17:54
I'd fight to get the remaining sectors...should be able to mount directly within Linux.
PostPosted: November 8th, 2013, 19:08
Consider me fighting. Will get back to you. Thanks for your help :D
