 Post subject: WD HHD Problem
PostPosted: November 29th, 2013, 3:56
Last week my 2TB WD Caviar Black HDD gone bad. No and anytype of sound coming out of it. But it shows 0.0gb in my bios. Is this PCB issue. changing pcb or swapping rom resolve this or what?
 Post subject: Re: WD HHD Problem
PostPosted: November 29th, 2013, 4:01
What do you mean by "no noise"?
Is it spinning up?
PostPosted: November 29th, 2013, 4:19
no its not spinning at all, no noise coming out of it, but it showing 0.0GB in bios.
PostPosted: November 29th, 2013, 5:21
What are the full model of the drive and PCB? WD..-... and 2060-...
PostPosted: November 29th, 2013, 6:19
Then you can try and new PCB with ROM swap.
If it doesn't have an external ROM at U12, then you need pro help
PostPosted: November 29th, 2013, 6:37
Its full model is WD2002FAEX-007BA0
and
its PCB model is 2060-771624-003
PostPosted: November 29th, 2013, 19:14
Seem like those have ext ROM.
Follow pcimage's suggestion.
You can also check some of the components with a multimeterif you have one and have basic electronics understanding. Use the search function. May be easier to restore. It all depends on damage extent.
PostPosted: November 29th, 2013, 20:54
I would think that if the drive identifies itself to BIOS, albeit with 0 LBAs, the this would mean that a large part of the PCB is OK.
Could it be that the MCU cannot see the preamp, and would this produce the observed symptoms? If so, perhaps the OP could examine the preamp contacts on the PCB.
Oxidisation on Western Digital PCBs:
http://malthus.zapto.org/viewtopic.php? ... 649&p=1789
PostPosted: December 26th, 2013, 12:33
i tried new PCB with bios swap but no use. same condition not spinning up and showing 0.0gb in BIOS. any recommendations. I have attached the picture of PCB, there is pointer pointing towards replaced chip. Any more chip that has to be swap.
File comment: PCB
PostPosted: December 26th, 2013, 13:42
if you are looking for data on this drive, we can help...
PostPosted: December 26th, 2013, 18:22
ahmad21 wrote:
I have attached the picture of PCB...
Clean the HDA contacts.
PostPosted: December 27th, 2013, 1:04
Spildit wrote:
Did you try the donnor pcb with the donnor rom (without rom swap) ? Does it spins that way ?
Insulate the head contact on pcb with a piece of plastic foil. Does it spins that way ? If so pre-amp inside the head stack is most likely shorted.
Do you have any tool like wdr, salvation, etc ?
Yes i tried that way also but no use, same condition not spinning. No I have no tools. But there is a person who have PC3000 only. Actually i am not the professional specially for hdd and also there are no hard drive experts in my country. I live in Pakistan.
PostPosted: December 27th, 2013, 5:50
[/quote]
Yes i tried that way also but no use, same condition not spinning. No I have no tools. But there is a person who have PC3000 only. Actually i am not the professional specially for hdd and also there are no hard drive experts in my country. I live in Pakistan.[/quote]
with all due respect, I disagree with you that there are no professional in Pakistan, which city you are from ?
leave your contact detail here...
Data Recovery Pakistan
PostPosted: December 30th, 2013, 8:13
I live in Lahore. My mobile no is 0321-8809354.
Users browsing this forum: Google [Bot] and 100 guests
