 Post subject: Seagate 1 TB ST1000DM000 noise and stays busy
PostPosted: November 27th, 2013, 4:54
Hi Folks,
I have got a Seagate 1 TB ST1000DM000, 9TS15E-570 FW:CC93.
When i got it from the customer they said that it was dropped slightly, then it worked for a bit and stopped id on BIOS.
I connected it to terminal and got the following messages:
"Rst 0x20M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
FAIL Op=0100 Resp=0003
No HOST FIS-ReadyStatusFlags 2002B001"
I assumed it is heads so i opened the drive and it was in a pretty good condition and heads looked good under a scope. The only thing i could see was light curving of the external edge of the platters, but couldn't see any particles on the HDA filter.
I cleaned the platters very carefully with IPA 100% and clean room wipes and than replaced the heads with an identical donor heads from a very good matched drive.
Head swap went smooth and looks good, but i am still getting the exact same result in terminal and same noise, please listen to record on this link:
https://dl.dropboxusercontent.com/u/495 ... -noise.zip
Any ideas what it is, do you think it is still recoverable or SA can't be found as a result of media damage?
Thanks,
Oded
 Post subject: Re: Seagate 1 TB ST1000DM000 noise and stays busy
PostPosted: November 27th, 2013, 5:13
I did not yet listened to the recording, but have you btw returned heads back to donor, just to check if they are still ok?
PostPosted: November 27th, 2013, 5:26
I'm trying to avoid back and forward swaps to keep heads in good condition but i'll try it out if there is no other resort
PostPosted: November 27th, 2013, 5:28
It's a test that I always like to do, to be sure that it's not a surface issue, but a FW issue.
PostPosted: November 29th, 2013, 19:04
Last time I heard that noise I finally discovered a ring headcrash very close to the inner diameter on one of the surfaces. Did you check the filter for particles under a good microscope, or just by naked eye or magnifying glass?
PostPosted: November 29th, 2013, 19:18
With visible light media damage, the filter can still be clean.
Users browsing this forum: No registered users and 75 guests
