 Post subject: SP1644N and SP1604N
PostPosted: April 3rd, 2009, 7:19
Hi to all! :mrgreen:
Somebody knows here to inform which to me the physical difference between these models?
or still if the heads could be compatible?
:idea:
Нет ничего невозможного
 Post subject: Re: SP1644N and SP1604N
PostPosted: April 3rd, 2009, 8:56
I don't know about these two models specifically. In general, when matching Samsung heads you have to have the same code to the right of the serial number, e.g. P/V MS.
You can use a 4 head head stack to replace a 3 head - I've done that.
If I had to guess . . . and it's only a guess . . . I'd bet these two are different.
Jono
http://www.datasaversllc.com
PostPosted: October 21st, 2013, 14:50
Hi everyone. I know this thread is very old but I have the same question and I don't quite get Jono's answer.
I have a broken Samsung SP1604N S/N: S013J10Y930726 P/N: 0923J1FY918104 P/V FS
I wonder if I can use a Samsung SP1644N S/N: SOE9JQSQ400139 P/N: 35041QSQ400100 P80M as a host to save the data. Any thoughts?
Thanks!
PostPosted: October 21st, 2013, 16:25
When you say "host" do you mean "donor"?
I have gotten the SP1624N and HD160JJ/P to work as donors for the 1604N. The SP1644N may work as well. Look at the slider topology under magnification. If it's a match, try it.
Buena suerte.
Jono
PostPosted: October 21st, 2013, 20:57
Yes, I do mean donor. Thanks Jono!
PostPosted: December 1st, 2013, 17:25
Hi everyone, I did the swap and I wanted to share my experience with you. I'm an amateur.
I didn't swap platters because the hard drive had two platters and I don't have the tools to do so without misaligning them.
So I swapped heads. At first it didn't work, the circuit board on one hard drive was REV A and the other was REV C. I'm guessing this was the reason. But then I putted the original board into the hard drive and it started no problem. There are errors here and there but I managed to get the important information out of the disc.
Thanks!
Users browsing this forum: No registered users and 86 guests
