 Post subject: ST31000333AS bad sectors stops drive
PostPosted: December 1st, 2013, 16:10
Got one of these in. 6 heads which seem fine but two of the surfaces have a lot of bads on them. Seems to have corrupted MFT.
Everytime it hits of the the bad sectors I have to get DE to switch the drive off and on before it will read again, is this normal or is there any way around it?
Imaging the 4 decent surfaces first then go back to the other two.
Atola insight wont do selective heads on this drive. I have a DDI on order but wont arrive for a week or two so DE is my only choice at present. Looks like this is going to take an age....Any suggestions welcome
 Post subject: Re: ST31000333AS bad sectors stops drive
PostPosted: December 1st, 2013, 16:34
Disable the defect adding and other options in "edit drive ID" in the Seagate utility.
See if that helps
PostPosted: December 1st, 2013, 17:26
oh yes.....should read manual! ill try that
ta
PostPosted: December 6th, 2013, 5:38
kpeddie,
this drive is already supported in new Atola Insight 3.2
Vitaliy Mokosiy
CTO, Atola Technology
Maker of MultiDrive
Users browsing this forum: Google [Bot] and 74 guests
