Infected with CryptoLocker Malware
December 9th, 2013, 1:22
I have a client which has CryptoLocker Malware infected to all his office files, any known solutions to decrypt the encrypted files?
Re: Infected with CryptoLocker Malware
December 9th, 2013, 5:10
That thread is not really useful. The short answer is there is no known solution for the more recent variants of this cryptolock, at least none that I am aware of. Each inidividual file on newer variants are encrypted with a new key, some variants claim to encrypt with 2048 bit encryption. Some of the older variants can be done, but if its a modern version Im not sure it can be done.
December 9th, 2013, 6:34
If it's the newer version (and I think so, as nowadays only new version is around), there's no chances without paying the ransom, because it's using asymetric crypto, and the private key is on the hacker server and without it no goal.
December 9th, 2013, 13:09
If you are lucky, the files didn't get erased properly -> try undelete/file carving.
December 9th, 2013, 14:32
If your computer has shadow copy enabled, you may have backup versions of the files which were not encrypted
http://www.shadowexplorer.com
December 9th, 2013, 14:56
I think the program will overwrite the sector that was in use by the file, that would be the way I would make that program work, not just create a new file and then delete the old one. Overwriting the content will make it impossible to recover. I've look up on this program, very nasty and makes me cringe whats around the corner.
At least that porn collection will vanish if you are in a pinch. Perhaps that would be a good evadance hiding tool if you are up to no good to run quickly when the FBI are on your doorstep.
I feer this is a deadly program that once open, you are royally screwed (Like Pandora's Box) unless you have a offline USB backup.
December 9th, 2013, 20:59
newer versions also search for networked drives and online storage. Ive heard from bob that more people are trying to find these guys and have a little chat than they are to prosecute them. I hope their OpSec is 100%, for their sake.
