 Post subject: WD 2.5" spin, click then stop
PostPosted: December 12th, 2013, 3:20
I have WD5000BEVT 2.5". I connect to PC. It spins up, clicks 1 time, stops then back to spin, clicks 3 times, stop. It repeats 3 rounds. On 4th round, it spins, clicks 1 time, stops then back to spin, clicks 4 times, stops. On 5th round onwards, it spins, clicks 4 times, stops. PC BIOS does not detect the drive. On imager, it spins, clicks 1 time, stop then back to spin, clicks 3 times, stops then enter DRDY state. After doing rescan, it spins, clicks 1 time, stop then back to spin, clicks 4 times, stops. It repeats 3 rounds then back to BSY state. Is it mechanical problem or firmware problem? and can it be fixed by serial terminal with usb to ttl adapter?
Thanks.
 Post subject: Re: WD 2.5" spin, click then stop
PostPosted: December 12th, 2013, 4:49
Probably it has damaged heads, but that need to be confirmed by a proper diagnosis made by a DR company.
If your data is valuable I would not try much more, because you can end up damaging the drive even more.
PostPosted: December 12th, 2013, 5:16
Exactly so.
Users browsing this forum: napalm_atx and 255 guests
