 Post subject: how to recovery/find separeta file from formated hdd
PostPosted: December 14th, 2013, 7:50
Hi
Plese help me, find way to recovery separete file from formated hdd. I have hdd formated and installed new system another time (NTFS) i try to find one file to recover. I know name file (example.mdb) and ia need recover this. I try use dmde but when i search ntfs volume i find more than 50 volume and serching anyone is take hoorible time.
This is a som simple way to search disk content for one deleted file?
any help will be appreciated
 Post subject: Re: how to recovery/find separeta file from formated hdd
PostPosted: December 14th, 2013, 23:40
I don't know if there are any tools that allow you to search for a particular file, but I suppose you could locate the MFT record for your lost file by searching for a unicode hexadecimal string.
For example, if the filename is "ABC", search for 41 00 42 00 43 00. It might take a long time, though.
That said, I'm not sure what to do when you find the MFT record.
PostPosted: December 15th, 2013, 4:14
I guess just the regular way. Use something like GetDataBack, do a full on scan, and if the file is there, select just that file. The db file is going to have to be in quite good shape to be of any value.
PostPosted: December 15th, 2013, 4:35
Another way can be to search for *.mdb files, some software allow you to search deleted files by types, File Scavenger is a useful utility for this job, search only *.mdb files and if you are lucky enough you will get the file...
Good Luck
PostPosted: December 15th, 2013, 6:33
Good Luck
Agree.
UFS explorer is pretty good at finding files by type, using the "intelliraw" feature.
However, if your drive was fragmented before you formatted, then you have much less chance of recovering the file intact.
Users browsing this forum: quinkq and 232 guests
