 Post subject: ST500DM002 No Detect
PostPosted: December 15th, 2013, 10:40
My Hard Disk Is :
ST500DM002
Firmware : KC43
IN The Bios Is identified , In Windows No Detected !!!!!
After Connect By TX And RX Controller Reply This Error :
Boot 0x10M
Spin Up[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MediaPartition:
Host LBA Length Disc LBA Length Start Cyl Head
Media Partition 00000000 00997AD8 00000000 00132F5B 00000000 000000
00
MC 00000000 0098A050 00000000 0013140A 00000000 000000
00
MSP 00990860 00000A68 0013210C 0000014D 0000076D 000000
00
User Partition 00997AD8 00132F5B 00000778 000000
00
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 060DBEBC 060DA1A8
Seg Write Preamble VBM start: 00000D3C end: 00000D63
Footer - start: 00000D65 end: 00000D8C
Seg Read Preamble VBM - start: 00000D8E end: 00000DB5
Footer - start: 00000DB7 end: 00000DDE
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 0011AFFD
[RSRS] 1779 DiscLba 000CD62C RW_RTL FFFFFFFF
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
MSP MainPOR:
MSP Init Metadata
Buf Bytes/VBM 00000208 DBA Base 06000000
Metadata size in bytes 0040
Num Segments 0053
Logical Sector Alignment 00000000
MSP Reconstruction
MSP Read ScratchPad Section 0000 DiscLBA 0013210C BlkSize 00000A60 Num Segme
nts 00000053 DiscLba 0013210C RW_RTL 000F4240
No valid segments found
MSP MSP Main Store Verify Reconstruction Status 10003000
Reconstruction Status 00003000
MSP Init ScratchPad on DiscDiscLBA 0013210C DiscSize 0000014C PhyBlkLBA 00990
860 BlkSize 00000A60
Write MSP Segment PhyBlkLBA 00990860 BlkSize 00000A60 DiscLba 0013210C
RW_RTL FFFFFFFF
MSP MainPOR: Complete
MSP MainPOR: Feature Enabled...
ScratchPad restore NOT required
Please Help Me To Fix This .
Thanks .
 Post subject: Re: ST500DM002 No Detect
PostPosted: December 17th, 2013, 12:55
What does the MHDD say ?
data recovery Poland
PostPosted: December 17th, 2013, 13:16
mo4sa wrote:
My Hard Disk Is :
ST500DM002
Firmware : KC43
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
(P) SATA Reset
MediaPartition:
00
00
00
00
MCMainPOR: Start:
[MCMTWS]
MSP MainPOR:
MSP Init Metadata
Num Segments 0053
MSP Reconstruction
RW_RTL FFFFFFFF
Thanks .
Dear Friend mo4sa
this is the common problem for KC41/42/42/44/45/46 and also for JC Series of seagate F3 Drives.
u need knoledge to resolved this issue no matter u have terminal adaptor or PRO tools.
easily fixed in less then 5 minuts.
yours friend
jignesh pankhania
PostPosted: December 17th, 2013, 13:29
Dear Friend mo4sa
yours friend
jignesh pankhania
kidly sir tell him the procedure to repair hdd . dont say that it is easy .
the forum is working for solution and problems . not for tricks without solution .
the post owner want solution and u reply unknow msg .
friend this hdd has latest firmware u need to short the pcb after second spinup msg appear in cmd after complete calibration of hdd then after ready status or any error or getting t mode u need to follow 0 capacity method
m0,2,2,,,,,22
/1
N1
then power reset
then use these three commands
F3T> F00A2,00,22
then F01E4,00,22
then F057C,043C,22
then /1
then N1
then power reset
this is correct method
if hdd is giving access to sector already and showing capacity then use only congen commands to stop relocations of bad sectors.
F00A2,00,22
F01E4,00,22
F057C,043C,22
regards
Waqas Ali
PostPosted: December 18th, 2013, 0:51
Does the User need to first list congen params to make sure the bytes changed are the correct ones? I reference a few of my previous posts
PostPosted: December 18th, 2013, 4:45
waqas_ali766 wrote:
Dear Friend mo4sa
yours friend
jignesh pankhania
m0,2,2,,,,,22
/1
N1
then power reset
F3T> F00A2,00,22
then F01E4,00,22
then F057C,043C,22
then /1
then N1
then power reset
F00A2,00,22
F01E4,00,22
F057C,043C,22
regards
Waqas Ali
Dear Friend waqas_ali766
R U Sure That your procudure is correct bcoz i am not using this procedur. and ya for solution i am not FREE consultants or advisor and my first rule is if there is any data recovery person have basic setup and skills then i helf them definatly. but for end user i dont. when i join and seen many things that first time i feel like u but now i understand everything and seen the factor is defrent then its seen so i stop myself to post solution in open.
i dont want to be an HERO and also dont want many thanx and yo man GREAT u DONE AMAZING. i am not work for just THIS.
this is the clear and fact and i always talk openly what i have in my mind wid no fear and no tear.
sorry if u dont like my reply or it hurt u but this is fact.
I realize that guru pplz right everything is not for sharing :D
I Seen here many pplz comes for free solution for own profit and be and hero to post on other forums leeching the stuff not make big defrence.
your friend
jignesh pankhania
PostPosted: December 18th, 2013, 7:11
dear in simple words u want to say don't help any one without taking money or fees or any other thing in return ?
am i right?
regards
Waqas Ali
PostPosted: December 18th, 2013, 7:34
Well my friend this forum is about sharing. Your right to not share is also acceptable, but you cannot speak for others. If you want to help, then help. We can not judge if the Original Poster is a business that wants to make a profit from the help or an individual that lost his family treasures. Just do what you feel is right and let others do the same.
Posting "this is an easy fix" doesn't help anyone, and also can give someone a false sense of security if they didn't describe their problem correctly, or run into issues, which happens a lot.
IT industry Famous Last Words: "This should only take 10 minutes!"
PostPosted: December 18th, 2013, 8:55
yes HAQUE .
i am with u . u r right .
PostPosted: December 25th, 2013, 9:08
am i right?
regards
Waqas Ali
Dear Friend Waqas_ali766
Dear Read What I Said Everything Is Clear, I have seen many things here that changed my mind and now i help them who is seriously in this Field and realy want to make carrier in this field. i dont like to help them who comes here for just time pass and leeching the stuff and post other blogs and sites.
i just sharing with them who is the realy in this field i always welcome for them and resolved their problems also spend my time for them on teamviwer to resolved the issue for TOTALY FREEEEE OF COST ,
yours friend
jignesh pankhania
PostPosted: December 25th, 2013, 19:13
Some people might get a thrill if they resolve the issue themselves with the guidance of a pro. They might not want the word done for them unless the data is very important and they don't want to risk it.
Shane
PostPosted: December 26th, 2013, 7:05
Shane
Dear Sir Shane
Some People Want Everything Free In Life But Dont Give Anything to This people is like Cell phone with out going blocked that i seen here they belive we are BIG FOOL and some short type U R THE MAN , THANK YOU VERY MUCH U SAVE MY LIFE , and many this type of word and make us happy and get what they want for free, intensinaly they are thinking we are fool they make us fool,
by this view i said that if people have no money and then why they dont go to shopping and bcoz they know very well that shopping not possible without money shop owner kick them out.
bye why here sinario defrent bcoz of some people dont in this business right and they are not dependent on it they family dont depend on it so they behave like this all is game but when some one doing this with thay business like this they realize each and every business running from mind and skills.
i am also againt that type of persons that charge very much for doing nothing its wrong.
but i am not favour that type of experts.
your friend
jignesh pankhania
PostPosted: January 9th, 2014, 2:19
Hello
I,m Do This And Get This Answer :
F3 T>
ASCII Diag mode
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>m0,2,2,,,,,22
Adr 00000002 ( 00000002 ) = 0002
F3 1>
ASCII Diag mode
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 1C, Max Certify Rewr
ite Retries = 0A8F
(DOS) Requesting File Save
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>/1
F3 1>N1
F3 1>
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
FAIL Op=0165 Resp=0005
FAIL Op=0055 Resp=0005
FAIL Op=0065 Resp=0005
(P) SATA Reset
MediaPartition:
00
00
00
00
MCMainPOR: Start:
Nonvolatile MCMT sequence number 0011B003
[MCMTWS]
MSP MainPOR:
MSP Init Metadata
Num Segments 0053
MSP Reconstruction
RW_RTL FFFFFFFF
ASCII Diag mode
F3 T>F00A2,00,22
(D) SATA Reset
Byte:00A2: RWRecoveryFlags = 00
F3 T>F01E4,00,22
(D) SATA Reset
Byte:01E4: BGMSFlags = 00
F3 T>F057C,043c,22
(D) SATA Reset
Byte:057C: PerformanceFlags = 04 3C
F3 T>/1
F3 1>N1
F3 1>
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
(P) SATA Reset
MediaPartition:
00
00
00
00
MCMainPOR: Start:
Nonvolatile MCMT sequence number 0011B004
[MCMTWS]
MSP MainPOR:
MSP Init Metadata
Num Segments 0053
MSP Reconstruction
RW_RTL FFFFFFFF
PostPosted: November 22nd, 2014, 7:25
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
(P) SATA Reset
Only this message appears and didn^t see the "F3 T".
Someone says "solution is easy". Yeah!..
May be he should write the same message on exam paper.
PostPosted: June 12th, 2015, 4:57
:roll: using the shorts pin and patience i recovered my all data.. :D
m0,2,2,,,,,22 is no harm to data..
PostPosted: June 20th, 2015, 16:24
In your case it was not. Quite often, drives develop issues in a manner where that command makes things worse.
Users browsing this forum: No registered users and 52 guests
